Low Beam Head Light Bulb
Hi Friends
I need your help.
I have Acura 2000 TL 3.2
Recently drivers side(low beam) headlight bulb got fused.
They are very costly at canadian tire
Can anyone recommend me from where i can buy them cheap and which color should i buy i.e (4000, 5000, 6000, 8000 etc)
Dilawer
I need your help.
Dilawer
www.theretrofitsource.com
Morimoto D2S 4300K or 5000K
Dilawer (04-19-2014)
Hid bulbs
You might try this site.
http://stores.ebay.com/SQM/_i.html?_..._sid=990260072
Can't say how the quality is, but the prices are good.
BK85
BK85
99-04 use D2R
The following 2 users liked this post by TLZINE99:
Dilawer (04-19-2014),
MrMoAcuraPar (04-19-2014)
The D2S is not much different, it only lacks a reflective strip that the D2R has. D2S is also much easier to find throughout the market. The difference in output/glare that the strip has is negligible. So you can put a D2S or D2C bulb in a D2R housing. Ask me how I know.
Yes the diffrence would be output/glare those strips is there for a reason. U dont want to put D2S Type bulb on a D2R type Reflector headlight assembly (2nd Gen) they would look funky and out of spec. They are mostly used for Projector type headlights assembly (3rd gen)
D2R = Reflector type headlamps (2ndGen)
D2S = Projector type Headlamps (3rd Gen)
check this
cheapest one
http://www.ebay.com/itm/371022294568...84.m1497.l2649
take some time(about 1 month) to deliver
cheapest one
thanks friends
highly appreciated for your time and help & suggestion
i will placed the order from ebay link provided by heedehis
but can one tell by checking this link will they are compatible with my car or .......
Listen or not, I do not care, I am just letting you know that there are plenty of options.
I can promise you, as a person who has a lot of experience with these headlights, HIDs, projectors, etc, the output difference is not there. You will not have glare above the cutoff, they will look exactly the same as a D2R. They will not look "funky and out of spec." Yes, D2S are prominent for projectors, but they work flawlessly in a reflector-based HID setup. The unblocked light from the D2S bulb is not going to stray above the cutoff, as the reflector pattern hasn't changed; it still focuses all of the light in the designed manner.
If there is no diffrence GREAT.. i have no prob .....man, those morimoto set up would be nice with 6k.
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
