Installed headers today
Old Nov 9, 2002 | 06:44 PM
bug230's Avatar
mushroom mushroom
Talking Installed headers today
My buddy and I instelled my headers today in exactly 2 hours. We had no problems except one. We wernt sure wich was the front and rear header (not labled). We assumed that the header with the logo tag welded on was the front but soon we found out that is was wrong. But none the less we still compleated the task in 2 hours. I can deffinatly feel that extra power in the higher RPM's.
Old Nov 9, 2002 | 07:37 PM
rock's Avatar
How difficult was it to install and what type of tools were needed? Someone told me that an air wrench was needed. Could it be done with one person using socket and box wrenches?
Old Nov 9, 2002 | 08:01 PM
ferizzo's Avatar
still a Masshole
I assume these are the OBX headers.
Old Nov 9, 2002 | 08:16 PM
asiankidd's Avatar
more info please i heard that alot of people are having problems with the check engine light....something about it blowing out all the junk in the pipes but just needs to be reset after break-in.....also what are the procedure with breakin and how muhc did you get your headers for?
thanks
JON LERD
Old Nov 10, 2002 | 01:09 AM
randomwalk101's Avatar
check engine light = forget to plug in the oxygen sensor..simple as that.
Old Nov 10, 2002 | 01:38 AM
drcookie's Avatar
Pictures please !!!!
Cheers !!!
Old Nov 10, 2002 | 02:57 AM
bug230's Avatar
mushroom mushroom
The install can be slightly tricky if you don't know what you are doing. But if you feel comfortable working on cars and are comfortable with a varity of tools the job can be done. If you haven't worked on cars that much I would not try to tackle this job. Installing a CAI sure but this was more complicated than that. For tools that are needed click on the link below there is a writeup from the A-CL.com site. I really don't think that air tools are necessary but are VERY helpfull. Yes, I think that this job can be done with one person but two people helped a lot, especially when conecting the A pipe to the headers.
http://www.acura-cl.com/forums/showt...all+header+obx
Old Nov 10, 2002 | 03:03 AM
bug230's Avatar
mushroom mushroom
thanks
JON LERD
No probs with the check engine light...not sure about the break in period (I don't think there really is one except checking conections a couple days after.) I got my OBX headers for $380 including shiping through massivemotorsports.com
Old Nov 10, 2002 | 03:07 AM
bug230's Avatar
mushroom mushroom
Cheers !!!
I didn't take any pics of the install. But if you want i can take pics of the headers intsalled? But they look just the same as the Comptech's on their web page.
http://www.comptechusa.com/instructions/ins028.pdf
Old Nov 10, 2002 | 07:47 AM
dj5's Avatar
dj5
Re: Installed headers today
I have had my Comptech headers on about two months. Took about 1 1/2 hour to install mine. My friend had installed two sets before so he knew what to expect. Enjoy....
Old Nov 10, 2002 | 09:50 AM
Which heade is that listed as?
http://massivemotorsports.com/main/o....htm#obxheader
I see no matching CL-TL header, only Accord up to 2000
Old Nov 10, 2002 | 10:59 AM
juniorbean's Avatar
The OBX headers are the same as the Accord V6 headers. They do not make headers specifically for the CL/TL... same as Comptech....
Old Nov 10, 2002 | 01:41 PM
Ray_Khan's Avatar
Hey BUG....
you guys use a lift or jack stands? I want to help Ferizzo do his, but I want to make sure we can do themon stands. Thanks.
Old Nov 10, 2002 | 05:05 PM
snapple's Avatar
I'm geting the Comptech Headers and does anyone have any suggestions before I install them.
Old Nov 10, 2002 | 07:00 PM
dj5's Avatar
dj5
air tools..
Old Nov 10, 2002 | 08:43 PM
bug230's Avatar
mushroom mushroom
Re: Hey BUG....
Yeah I used stands on the fronts. But if you have a OEM body kit on the front be carefull pulling it up. Too bad I don't...yet.
Old Nov 10, 2002 | 10:16 PM
snapple's Avatar
I might just have a shop do it for me don't know yet.
Old Nov 11, 2002 | 05:20 AM
Ya, i just installed my headers this morning. I can tell the difference already albiet small. Im not pushing the car too hard, i want to break it in first 200 miles.
In regard to fitment issues, hehe, there were some problems (downpipe needed to be bent a little so it would connect to the front header bank, o ring didnt quite fit in the end of the downpipe, nothin to serious), but i saved >$700 so im happy.
Old Nov 11, 2002 | 09:30 AM
ferizzo's Avatar
still a Masshole
I don't have the body kit either so I guess the jack stands should work then. Did you need to do any machining or did the holes match up well?
Old Nov 11, 2002 | 10:52 AM
eCo
I installed my headers yesterday with no major problems. Header holes all lined up well, and I could tell beforehand that would be the case by matching the headers against the gaskets.
Penetrating oil on all the old connections was a help pulling out the old parts. A 90 deg. air ratchet was sweet as well. Having a helper is a definite plus, especially tightening the headers to the A-pipe - one on top & one below. Keep all your connections loose until the end and you shouldn't have any problem pulling things together.
I've got the OEM body kit, and jack stands were not a problem. I used a 2x4 on my floor jack under a solid part of the frame to lift one side, then placed the jack stand under the normal lift point. Repeated this on the other side. I didn't lift the rear at all and had plenty of room. Be sure to chock it, tho.
Good luck to all.
eCo
2002 WDP TL-S
Headers
OEM Underbody Kit
WW Spoiler
Old Nov 11, 2002 | 11:26 AM
mikegunnz's Avatar
If anybody wants headers installed in the southern fairfield county area of Connecticut, I know a guy who does it for $100. He's done mine, and 2 guys on the CL board. The only problem hes had in the 3 installs is that one of the holes of the front header bank, is too small/not a perfect circle and needs to be shaved a little, but other than that everything is good. Oh and some headers come with 3 Orings, some with only 2. If you get a kit with only two orings, you have to go to an Auto parts place and get one. The Accord EX Oring fits, so thats all you have to ask for. (ask for the accord, bc most places have them in stock.)
Feb 25, 2020 09:57 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
bailey24
Nov 21, 2015 08:43 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
