I need some help/opinions
So Im On The Parkway, Take exit 153 or 154 for clifton, then my TCS and Check Engine Light come on, of course I couldnt press the TCS button to turn the light back off. I turned the car off then back on and the TCS light was off but I could press the button to turn it on and off as I pleased. I went to Strauss to see if they could check the codes but they charge 85 which is wackk...Today is really warm out..first time in a while so idk it could be the heat fuckin with the sensors. What could be it? where can I go to check the Codes? Hopefully its not tranny cause im screwed. Maybe one of you fellow TL'rs has the code machine thingy and could help me out..would be appreciated. Thanks!
theres no advanced around here....my bro led me to this link so it doesnt sound too bad (Hopefully)
/forums/f47/check-engine-light-after-93k-miles-80299/
BTW No D5 Blinkage. Well its D4 To Me But Still No Blinkage ('99)
P0401
Definition: EGR System Fault
Causes:
1. Blocked Passage on EGR System
2. Failed EGR Valve
3. EGR Solenoid Faulty
4. Failed EGR Pressure Sensor
5. Failed EGR Position Sensor.
Gay.
Now what?
Causes:
2. Failed EGR Valve
Gay.
Now what?
do the EGR port cleaning- inside the intake manifold- see the DIY, I think its pics are from a 99 no less!
Takes under 2 hours in total. Remove manifold- clean everything- reinstall- enjoy
https://acurazine.com/forums/showthread.php?t=156252
hopefully this is easy, I have contacted orgnlprankster7 to see if he could help me out on this. What do I need to do this other than the tools. I see I might need a new gasget to raplace anything else I need? where Can I get this gasket.
you will be fine- just take pics of assembled parts in case~
read the DIY a few times- go look under your hood- remove top cover- go read DIY again- feel safer- now proceed
take your own set of digital pics with all the wires and hoses tagged with masking tape and a letter or number or alien symbolgy of your choosing -
so YOU can make sure 2 similar connectors are back on correct places and coolant lines are not run to VAC port- it has happened more than once!! Makes car run baddddd
Clean EGR makes car run gooooood
So Just To Make Sure......I know i keep askin I just want a straight answer (yes Or No) Do I need anything else other than EGR cleaner fluid stuff and some tools? Do I need any Gasgets to replace or anything of that nature?
no
just the carb cleaner and the basic tools listed in the DIY, omit the part where you install a Thermoblock spacer-
and dont take the studs out of the TB to put longer ones in!!
Just clean the egr ports that look like exhaust crud is plugging them
So I attempted this today and I could not finish because the Throttle Body Did Not Want to Come Off....wtf If I pulled any harder the whole engine and motor and tranny would of just came out.
JDiMage
Apr 16, 2012 09:10 PM
