Hyper ground and voltage system.
Old May 19, 2004 | 04:51 PM
mllin68's Avatar
Question Hyper ground and voltage system.
I just installed my CAI in my TL and loves the feel of the ride. Now I'm thinking about Installing a Grounding system in my ride. The thing is I don't know which to choose from, the Hyper Ground System or the Hyper Voltage System. What is the difference between them? How will they improve my ride? Which one should I buy?
Please help, any suggestion is welcome.
Old May 19, 2004 | 05:57 PM
patrick's Avatar
From my understanding, the hyper grounding is all that...just hype. Save your money for better mods.
Old May 19, 2004 | 06:09 PM
patrick's Avatar
Take out the "*" from the links below for more info on why hyperground kits are bogus. Look for Austin519's comments in these threads.
http://www.a*c*u*r*a*w*o*r*l*d.com/f...g&pagenumber=1
http://www.a*c*u*r*a*w*o*r*l*d.com/f...ight=grounding
Old May 19, 2004 | 06:43 PM
thsiao's Avatar
Happy with my STi!
People often suggest to skip this mod as they think it brings insignificant if not zero gains in power. I have read many things about the Hyper Ground System and they do seem to help a little, 2 HP at the most. New cars usually don't need this mod because all the electrical stuff is high tech and electricity loss is at its minimum already. I would say save the money for something else.
Old May 21, 2004 | 08:13 PM
mllin68's Avatar
It seem like everybody thinks that this Hyper Grounding thing is not worth the money.
Thanks guys. I will save my money on something else.
Old May 21, 2004 | 08:38 PM
nortondlcl's Avatar
I have installed both Hyper Voltage System & Hyper Grounding on my 2002 TL type-s And yes I can feel a little more power off the line.
I would say for 2-5 hp its worth it.
Old May 21, 2004 | 08:49 PM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
Don't skip the hyperground - just don't buy a pre made one..
get a few feet of four gauge wire and a handful of compress connectors, that is exactly what they will sell you for 90 bucks and you can buy the supplies for less than 40 and do it yourself.
Old May 22, 2004 | 03:43 AM
eh!curaplus's Avatar
Team INSPIRE Canada
that's exactly what i have
i have a custom made grounding kit, 4gauge wiring with gold plated connectors. do they work? i couldn't tell you if there was a diff. what is diff is i get a whining sound any and everytime i turn my wheel. i think it has something to do with the fact that it's connected to the power steering pump? dunno why, but it does!
Old May 22, 2004 | 10:17 AM
Tatewaki's Avatar
I have the grounding kit too. Like they said, I couldn't tell any diff. But it can only do good and no harm
Old Oct 31, 2006 | 02:15 AM
vzuptnguyen's Avatar
B A N N E D
wats the difference between hyper ground and hyper voltage, i saw some people at meet with these and want to look into it. can someone explain me a little brief "ground/voltage systems for dummies"
all opinions greatly appreciated. thank you.
Old Oct 31, 2006 | 07:53 AM
NSXNEXT's Avatar
It's all in your head. No way on god's green earth are you going to be able to feel 2-5 hp difference on a 260 hp car. Not happening.
Old Oct 31, 2006 | 11:02 AM
TunedTL's Avatar
Initial D
Yes, but the $ to HP ratio is better than other popular mod such as catback/axelback exhaust. Turbo will give the most gain but not few have the $ and time to invest in such custom project -> highest absolute gain is nice but not everyone can afford it.
Old Oct 31, 2006 | 11:15 AM
fsttyms1's Avatar
He never said it wasnt worth the $$
He said and i quote................
and i agree.
Old Oct 31, 2006 | 11:54 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
make your own kit... it's so easy..
it'll help your gaz milleage and will help the car's electrical system to work better/easier... and it can make your car "quicker" off the line... it helps give it a little punch.
Old Oct 31, 2006 | 12:20 PM
Billy Sacco's Avatar
Kilos of yayo in
http://forum.sounddomain.com/ubb/ult...c;f=5;t=007801
Just follow that link and do the above procedure. IMO way better then any grounding kit. A lot of these grounding kits have you bolt everything to some metal plate which is less then ideal. If you run any kind of aftermarket sound system in your car you should definitely do the "big 3" as it’s called in the thread above. I can tell you that after doing it in my car I did notice just a tiny bit more responsiveness. I don't think you gain horsepower or anything but your alt should run more efficiently so might tax the engine just a bit less. Also the method above is like $20 in wire and connectors.
emailnatec
29
Sep 28, 2018 04:27 PM
lbabus
Oct 12, 2015 07:00 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
ripit
Sep 26, 2015 06:19 PM
agupta3224
Sep 22, 2015 08:08 PM
