Help !! Driver side hid shutoff after driving for a while
Old Nov 1, 2019 | 05:47 AM
max4swag's Avatar
Hey everyone I need help for this issues that has appeared , it happened once 6 months ago I hit a bump and my driver side headlight turned off but when i would turn off and on it would work again no more issues for 6 months , but now 6 months later it shut off after driving for a while when I flick the lights off and on they turn on again I thought it might be the headlight bulbs I replaced them both a couple of days ago and this still happens ? What should I verify
thanks !
Old Nov 4, 2019 | 12:18 PM
Arkady's Avatar
Hey, that was happening to me too. Try swapping the sides that the ballasts are on, and seeing if the issue changes what side it happens on.
I ended up just changing my entire light system out, as it wasn't much more expensive than getting new OEM parts. You can find pictures and a list of parts over on the Photographs sub-forum here
Old Nov 4, 2019 | 11:00 PM
max4swag's Avatar
What’s weird is that when I leave the car on for around 30 minutes with headlights on they do not shut off as soon as I start driving the driver side one will shut off always at a different time and sometimes it il will work for a while ...
Old Nov 4, 2019 | 11:05 PM
Arkady's Avatar
Yeah, i figured it was a bump on the road causing it, because I was having the EXACT same issue.
Old Nov 5, 2019 | 07:19 AM
max4swag's Avatar
Could it be a loose connection or ground or is it really the ballast dying ....? I find it weird that when it only turn it on without driving it does not shut off by itself
Old Nov 5, 2019 | 08:44 AM
Arkady's Avatar
I wasn't able to find the bad connection. I did swap sides with the ballasts, and the problem traveled with the ballast. Later on both ballasts were doing it. Of course I also wanted to upgrade my lights anyhow, so I was biased towards replacing the whole thing anyhow :P
Jonjonn420
May 23, 2016 02:03 AM
Blackmateria87
Nov 4, 2013 04:08 PM
jon2000
Jan 20, 2013 12:59 PM
ABP_04TL
May 23, 2012 08:50 PM
GeorgiaNative
Oct 7, 2006 06:53 PM
