Xenon/HID issue
Old Jan 14, 2013 | 08:25 PM
jon2000's Avatar
Xenon/HID issue
Hi everyone,
I just swapped out my headlights to a custom set by JNC this weekend (who did a great job on them btw) and also put in new D2S Morimoto 5000K Xenon bulbs since my stockers were aging.
I drove around last night and both driver and passenger xenon bulbs were working great. I turned the car off which also turned the lights off but realized I wanted to quickly check the cutoff. I turned the headlights back on and noticed only the passenger side ignited. Tried again - same thing. Turned the lights off and let everything settle for 5 seconds, tried again but this time it worked. I checked the lights again before I went to bed and they fired up the 1st time. I checked things today after work and noticed the driver side didn't fire if I turned the lights on right after turning them off. Again, if I let everything settle for 5 seconds they both work.
I believe my battery may be on its way out but I don't think this would cause this intermittent headlight issue.
Possible bad headlight bulb, bad ignitor, bad ballast, just a quirky thing to deal with? Thanks in advance for your thoughts and opinions.
Jon
Old Jan 14, 2013 | 08:52 PM
ep3kid914's Avatar
im having this same problem too on my passenger side.i replaced both ignitor, ballast and bulb but dont turn on right away if i turn it off only if i wait a couple of seconds
Old Jan 14, 2013 | 10:30 PM
jon2000's Avatar
Good to know! Thanks. I don't think I ever tried turning them on right after they were off before swapping out the headlights so maybe they've always been this way? You've replaced all the components I listed as potential sources of the issue so I'm not sure why this would happen. Hopefully others will comment.
Old Jan 20, 2013 | 12:59 PM
jon2000's Avatar
Anyone else experiencing this? I can replicate it by turning the headlights off then back on quickly. Happens 90% of the time and only on the driver side.
Thanks,
Jon
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
