Header Gaskets for TL Type-S
Old Oct 27, 2006 | 06:02 PM
drcookie's Avatar
Does anyone know if Honday dealer carries similar header gaskets for their Accord v6 ?
If they do which model and year should I ask for? I have a 2002 Acura TL Type-S.
I called up a few Acura dealers and they all told me this is a special order item.
The price ranges quoted from Acura dealers was from $22 each to $26 each.
Looks like I have to wait for my DC header upgrade.
Please advice.
Old Oct 27, 2006 | 06:48 PM
stRodda's Avatar
when i put the headers on, i just reused the stock gaskets. no leaks at all. and i believe you can use the gaskets from the 3.0 v6 accord, since thats what the xs headers are from.
Old Oct 27, 2006 | 09:40 PM
drcookie's Avatar
Thanks. I will try the existing gaskets and hope every goes just fine.
Old Oct 28, 2006 | 09:03 AM
fsttyms1's Avatar
Just reuse the stock gaskets as long as your careful and dont damage them
Old Oct 28, 2006 | 10:54 AM
JnC's Avatar
JnC
Former Sponsor
I thought the same thing when i got my comptechs installed i.e. that i would need new gaskets, but the dealer ended up using the old ones and they work just as fine.
If you really need a pair then i got one sitting with me that i bought just in case. PM me.
Old Oct 28, 2006 | 11:34 AM
Excelerate's Avatar
Former Sponsor
Just re use your stock ones. They are Multi Layered Steel and they can be reused.
Old Oct 28, 2006 | 01:43 PM
Phrosttz0's Avatar
how bout bolts you guys recommend getting new ones or replacing, what size?
Old Oct 29, 2006 | 12:14 AM
drcookie's Avatar
Thanks guys for the info. I did the install today. I had two front rotors replaced and also the header. It took me 5 years for both jobs. I was lucky. All the bolts came off easily with a little bit of force.
I reused the stock gaskets for the headers and they worked just fine. However, I have a small leak between the front header and the A-pipe (I think that's what they call it). I used the copper gaskets and not the one that came with DC Sports. I did not notice any leak at the rear end.
Do I need to take the whole pipe apart again if I need to replace/fix the front gasket?
Please advice.
Old Oct 30, 2006 | 03:03 AM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
the bolts are
10mX30 8.8 strength
you can use the 10X40 bolts but it doesnt do anything but force you to use the deep sockets.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
DerrickW
Nov 15, 2015 05:52 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
