Green power steering
My power steering fluid has turned green. NO I HAVE NOT USED GREEN FLUID. I usually use either red or clear.
I did a power steering flush 3 times and each time came out green again?
Any suggestions on what to do besides take it to the shop? Oh it’s a 2000 Acura TL 3.2L
Yeah, give it a cheeky lil' taste test. Just to make sure it's not just coolant.
I can't imagine that coolant would be able to get in unless you hooked something up way wrong, but this is mainly to confirm that you're not just looking at the wrong reservoir or something.
The steering fluid I use turns a dark brown when it's old - is that the color you're seeing, or is it straight-up coolant green?
I haven’t worked on it. I checked it about a month ago and it was red. The color is straight coolant green. Bright. It does smell a bit like coolant when it gets hot. My power steering pump is now leaking.
Arkady (04-02-2020)
smells like coolant, looks kinda like coolant - taste it later and let us know if tastes like coolant too. that'd be some weird power steering fluid, huh?
are you sure you didn't confuse the reservoirs? the power steering and coolant overflow reservoirs are right next to each other.
it tastes nasty, super bitter. please don't like drink it, it's kinda poisonous. i just dip the tip of my pinky in and lick that if i need to taste test.
Aandb919 (04-02-2020)
Still need to see a pic of the fluid. the reservoir looks like it has black fluid in it. If you are concerned about the color of the fluid, good. It's said that old fluid will contribute to breakdown of seals in the power steering rack. I'm told the primary cause of fluid breakdown is oxidation and worn out hoses.
There are a few ways to refresh the fluid, but honestly if you want the fluid to stay good for a while you should replace those hoses; some look original, but with aftermarket clamps.
@whitetiger5 it does look dark, because we added Powersteering Lucas in. However that probably shouldn’t have been done. We are replacing all of the hoses and the pump, probably along with the serp belt. Thank you for the info.
@thoiboi you sir, are a dick. I’m pretty sure me and the 4 people that have looked under my hood. Perhaps you don’t see the fluid drip on the hose. Your opinion is no longer needed. Thanks.
Honda’s hate the aftermarket stuff and you’re guaranteed to run into problems if it stays in your system for too long!
Arkady (04-03-2020)
Aandb919, a word to the wise. This forum has a wealth of information and it's members are extremely knowledgeable about these vehicles. If you have a question, be specific with as many details as possible but do your homework first using the search function. Most peeps around here will help you with open arms if you show a little humbleness and respect, but the second you start with the name calling or high and mighty attitude i guarantee you won't last a second!
Regarding your power steering fluid issue, the fluid in there needs to be 100% flushed out and replaced with genuine Honda PS fluid. As Darksyne mentioned, these pumps do not play well with any other type of fluid.
Aandb919 (04-11-2020)
