Engine Swap?
Old Aug 15, 2005 | 05:41 PM
acrite's Avatar
Engine Swap?
can an engine from an 04 05 tl be swaped into an 02 tl-p?
Old Aug 15, 2005 | 05:54 PM
Pure Adrenaline's Avatar
Dragging knees in
The right question is, how much can you spend?
Anything's possible with money.
Old Aug 15, 2005 | 06:02 PM
acrite's Avatar
what i meant is will it bolt right in or will there be a lot of modification?
Old Aug 15, 2005 | 06:54 PM
BIG_KOUT's Avatar
you might as well buy an 04
Old Aug 15, 2005 | 06:57 PM
mclarenf3387's Avatar
J32A3 = teh suck for modding
J32A2 = the shit for modding
If anything, swap in a Type-S motor. But build it up first.
Old Aug 15, 2005 | 07:01 PM
Dragging knees in
Exactly.
Old Aug 15, 2005 | 09:27 PM
fsttyms1's Avatar
Old Aug 15, 2005 | 10:39 PM
acrite's Avatar
i found an 04 05 engine w/only 20 miles on it for only 3000. just wondering if its possible. besides theres not much diff between a typ s and a p. cams, throttle body, im doing all that all ready. it was just a thought
Old Aug 15, 2005 | 10:48 PM
Dragging knees in
Find a J32A2 out of an '03 CL-S 6-speed. J32A2 has much higher potential than the J32A3 in the 3G TL. With the current offerings from the aftermarket, you can achieve *maybe* 300 hp with the A3, except for supercharger.
With the J32A2, you can achieve 330 hp easily with bolt-on's before going forced induction.
Either way, you'll have to rewire the car so that shouldn't really affect your reasoning. However, what should affect your reasoning is that the chassis were the same for the J32A2 between the CL and the 2G TL, and it will MUCH easier to drop in an A2 6-speed out of an '03 CL-S.
Old Aug 15, 2005 | 10:58 PM
samkws's Avatar
Comptech Freak
04 TL u cannot put a header.....no good
Old Aug 15, 2005 | 11:02 PM
Dragging knees in
Well, shit, if he's going to swap it in, he could have the shop cut off the exhaust manifold and put on new pipes. You can do just about anything while the engine's out. The sky's the limit... and the wallet.
Old Aug 15, 2005 | 11:19 PM
samkws's Avatar
Comptech Freak
sky is the limit...a supercharge NSX....
with champion white and 19" wheels
Old Aug 16, 2005 | 03:01 AM
acrite's Avatar
damn!!! thanx alot fellas! appriciate the input. this is the reason i stay commited to this site.
know i now better. typ s is the way to go as far as mods. thx again
Old Aug 16, 2005 | 08:46 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
as far as i can tell you it *may bolt* in but the drive by wire feature will screw with your computer. you would have to check into computer compatibility and things like that. i agree with everyone else. your best bet is to beef up a type-S motor. good luck!
SSTS
Old Aug 16, 2005 | 08:47 AM
ChairmanMaoSaysRTFM
does it really need headers though? i thought the additional 10hp was gained from freeing up the exhaust a bit, or am i totally wrong? (of course i see the fact that a header would be good for 20hp instead of the 10 you gain from the 04+ TL redesign).
SSTS
Old Aug 16, 2005 | 10:08 AM
fsttyms1's Avatar
SSTS
Any Hp is good Hp
Nathan Allan
Jul 1, 2023 06:33 AM
dirtyspitshine
Jan 3, 2023 08:23 PM
LECKEY73
Feb 22, 2016 01:32 PM
justin7779
Dec 25, 2015 10:33 PM
02tljj
Sep 11, 2015 12:37 PM
