Does anyone know if the Rack & Pinion on a BASE and Type-S Model are interchangable?
Old Nov 10, 2010 | 05:55 PM
johnny14's Avatar
I know there are different but Im just curious if I can mount up a 02/03 Rack & Pinion to my 1999 TL Base? Is all the mounting points the same? I know the lines are different as well but my main concern is the mounting points. Can anyone confirm this?
Thanks,
J14
Old Nov 11, 2010 | 11:02 AM
johnny14's Avatar
anyone?
Old Nov 11, 2010 | 11:33 AM
acutee's Avatar
TL-P and TL-S are not interchangeable. 99 tl and 02-03 tl is interchangeable.
Old Nov 11, 2010 | 12:48 PM
fsttyms1's Avatar
^ yep, the TL-P uses variable assist ps that gets powered/assisted by the trans the TL-S does not.
Old Nov 15, 2010 | 11:37 AM
johnny14's Avatar
Thanks for both your input.
Here's the thing.....I did the Type-S conversion so Im not using the variable assist ps that gets powered/assisted by the trans anymore as my new Type-S tranny doesnt have it. I tried to bypass it by running a loop which is working fine but Im noticing that my steering when turning it squeeks really bad. I believe since I dont have that tranny assisting pump anymore something is not flowing correctly which is causing the squeling. If I can keep my steering rack and figure out a way to fix the squeling Im all ears.
The reason why I was thinking of just swapping out the entire rack and pin I figured it would be easier but once again the mounting points is at question. I should have clarified a bit more! Sorry.
So now with that said and done does anyone know a way of resolving this without replacing the entire setup of one from a type-s?
Old Nov 15, 2010 | 01:56 PM
fsttyms1's Avatar
Are you sure the belt is tight enough? How is your fluid level. Mine is bypassed with the loop and it works just fine.
Old Nov 15, 2010 | 04:11 PM
johnny14's Avatar
Belts tight enough not to loose not to tight. Fluid levels are fine. Internesting so you looped yours and your is fine? Thats good to hear I was really hoping not to replace the steering rack as mine was in well working order prior to the conversion. hmmmm I wonder if my pump may be dying? Any other insight you can think of?
Old Nov 16, 2010 | 11:56 PM
johnny14's Avatar
Is there anyone else who has swapped tranny's with a 6 Speed where the tranny no longer utilizes the variable assist ps that gets powered/assisted by the trans and did you loop it and everything works fine?
I just want a few more confirmations if possible before maybe purchasing a new power steering pump since Im not sure what else it could be.
Thanks in advance
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
thomask
Sep 21, 2015 03:01 PM
miguelalanis
Sep 21, 2015 01:04 PM
CaliBud916
Sep 19, 2015 01:56 PM
