Do your own brakes?
Do your own brakes?
How many of you do your own brake job? I went to PT in Redwood City, CA and they seemed to have some trouble. I ended up going there 5 times to get it checked out and fixed. I did end up with new rotors in the back and new pads after 3 weeks for free under their warrenty but my time is precious and i can't afford to spend 10+ hours at the shop.
so if you do your own brakes:
what brand you use?
how much?
how do you change it?
how easy is it?
do you change rotors too?
where do you get your rotors machined if you need to?
any special considerations?
any help would be awesome.
what brand you use?
how much?
how easy is it?
Do it yourself and you'll save $$$$$.
If you have vibration then go and get the rotors replaced/shaved. I recommend replaced since there isn't that much cost difference.
Changing brakes in Acuras is pretty simple, I've done it about 3 times on my Legend (both disc) and they work great, haven't had the need to machine them yet.
Originally Posted by AcuraTl203
u need an impact screw driver to take the rotors off , get them machined at autozone , pads are easy but it is a safety issue so if ur not sure let the pros do it
Never go to the dealership for this unless you're still under warranty...Autozone, Auto discount, Tire kingdom, Quaquer State...i could keep going on and on...
Originally Posted by etxxz
No dud, a wratchet and an extension (a tube or something to use w. wratchet) is MORE than enough...theres only 3nuts plus the break line holding the caliper in place...It takes 5minutes to take each caliper off...plus lifting and taking rims off
as for the brakes 2 bolts is all you need to remove the caliper. you dont need to remove any brakelines or brackets that hold them. that and either a large chanel locks or a big C-clamp for the brake piston.
its a EASY job
i'm thinking about replacing my front rotors and pads too. seem to be getting vibration while at speed and i know my rotors are wearing thin from resurfacing. when you guys change your brakes is it safe to just use a jack or do you recommend jack stands?
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
