Which coolant is better?
Old Nov 14, 2002 | 12:53 PM
Harvaline or Prestone????
thanks for the input
Old Nov 14, 2002 | 05:19 PM
fla-tls's Avatar
On the way!
Acura recommends that you use a coolant with no silicates. I know regular Prestone has silicates - but I'm not sure about Havoline.
Read the label on the back to see if it contains them.
Old Nov 14, 2002 | 05:34 PM
redryder83's Avatar
SpOon!!!!!!!
Redline Water Wetter!!!!!!!!!!!!
Old Nov 15, 2002 | 09:18 AM
kent_99TL's Avatar
Just go for Honda factory coolant.
Old Nov 15, 2002 | 01:30 PM
learned the hard way
I highly recommend sticking with Honda coolant. I had an Accord that I filled with Prestone--the whole system filled up with corrosion after about 30K miles.
-J.P.
IMHO the same thing goes with transmission fluid, power steering fluid, and brake fluid. Honda has gone to a lot of trouble to develop fluids that are compatible with their systems and keep the seals lubricated and corrosion at bay.
Old Nov 15, 2002 | 04:52 PM
Thanks guys. Honda Coolent....Here I come!
Old Nov 16, 2002 | 01:35 PM
Seotaji's Avatar
the havoline/prestone dex cool approved coolants are silicate free.
they are the ones to use.
Old Jan 31, 2026 | 04:01 AM
Yer boy's Avatar
I understand your point and that it's better to not take any chances. However, some Honda/Acura products are made by other companies and you can buy direct for better prices.
For instance, Honda/Acura Type 2 coolant is made by Pentosin. Pentosin Pentofrost A3 is the same coolant and it's typically much cheaper.
cycdaniel
Dec 17, 2019 10:58 AM
merc009
Jan 27, 2016 10:34 AM
LeVeL
Oct 18, 2015 04:19 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
