CD Changer
Old Jun 19, 2001 | 06:08 PM
PaulKCK's Avatar
Post CD Changer
Jay Wolfe Acura replaced my CD Changer today. Went out at 3 weeks. After a day in the heat, CD changer flashed Er-01 and began to eject CD's. New one works great.
Don't know if my CD-Rs had anything to with it.
Loving my Type-S. By the way, 4 Expressos and Kid Rock do not mix with rush hour traffic!!! (Expressos compliments of the Acura dealership while I waited)
Old Jun 19, 2001 | 10:10 PM
Post
Hey,
The same thing hapened to me a month ago.
They replaced the whole unit and it works fine. I am not using any CD-R inside since then.
I am wondering if this is the cause of the problem? Mine showed ER-1 and did not want to play nor eject the 6 CDs inside(including 1 CD-R).
Any comments, please let know.
------------------[*]2002 TL-S Satin Silver Canadian model[*]50%-35% Tint[*]Ebony wood kit from snook789
Old Jun 20, 2001 | 10:02 AM
R Man's Avatar
Post
I've heard of CD changer problems caused by the stickers on CD-Rs. You can use CD-Rs as long as they don't have the stickers on them.
Old Jun 20, 2001 | 10:05 AM
rockinTLS's Avatar
Post
I have had the car for two months and have never had any problems with using them.
I usually have anywhere from 2 to 4 CD-Rs loaded in the unit at any given time. I don't use the paper labels, just write right on the CD. I heard the heat will make them peel off and jam the unit.
The only oddity my car has displayed regarding the CD changer is that sometimes when I switch from CD to FM to CD, the CD does not pick up where it left off.
No answers to the dilemma, just no problems to report...
Old Jun 20, 2001 | 10:09 AM
Post
Too bad they can't replace it with a unit that will read MP3's.
Old Jun 20, 2001 | 10:49 AM
MBA
Cool
Is it ok to leave the cds in the car ie parked in the hot sun while at work?
I'd like to be able to use all 6 without worrying about a cd meltdown. I assume the changer is totally insulated? Thanks.
2002 TL-S Satin Silver - no NAV
Old Jun 20, 2001 | 08:21 PM
PaulKCK's Avatar
Post
As far as I know it is as insulated as the rest of the car. But black interior gets pretty hot!
I will just use original CD's for now. By the way I had just used CD-R's where I had written on them, no stickers.
Old Jun 20, 2001 | 09:42 PM
Post
That's kind of disturbing to know that you were using CDRs without labels. I can kind of see it though. Manufacturer CDs have a metal layer that contains the pits that is pressed between plastic layers. CDRs are all plastic, and I imagine that at least the middle layer is a softer plastic, since it is designed to be melted by the laser when you are recording. I guess conceivably you could melt the plastic if the car got hot enough.
Sep 21, 2015 08:44 AM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
Chris.Su
Aug 13, 2002 07:09 PM
ChrisK_RENAMED
Mar 15, 2001 04:05 AM
