cat question...help!!!!!
Old Jul 21, 2010 | 04:46 PM
jp75's Avatar
ok...if my car has california emissions....do i need a california emission cat even tho i dont live in california???would this cause cel if i get 49 state legal cat???i have a califorina emission o2 sensor...it was the same part # as the 49 state o2 sensor tho..idk..anyone???
Old Jul 21, 2010 | 09:52 PM
01tl4tl's Avatar
so you have a Ca car you now have in another state and need to pass smog- is that correct?
Ca standards are the toughest so all other states accept them
Never heard of any probs with aftermarket units ordered thru Excelerate
and used in every state- Call Josh there and get pro info
Im not sure the differance in a Ca. cat---anyone? acura techs? fries?
Old Jul 21, 2010 | 10:37 PM
jp75's Avatar
i live in connecticut..but have california emissions according to my vin,,called the dealer cus i wasnt sure...theres a sticker under the hood...but i have a aftermarket hood...i dont see why i cant use a 49 state cat...idk tho...cali cat is alot more too..
Old Jul 21, 2010 | 10:45 PM
gold2003tl (90)'s Avatar
2003 TL-p
id go by the state you live in, and some states its by reign you live in. check local laws, if the car is getting inspected in Connecticut then go by there laws i guess. 49 state legal stuff should be fine, cant see why not.
Old Jul 22, 2010 | 12:50 AM
01tl4tl's Avatar
if it cost more there has to be a differance like an extra air port connection for our additional requirements
for the car to run right- call Josh at Excelerate--look in the sponsored sales threads
its not about where you live now,,,there are different parts in some cases
I know in Ca an older car cat is 99$ installed, and the newer obdiII cars we have are 150-300 for its cat
edit- I sent a PM to Josh with this thread link
Old Jul 22, 2010 | 01:30 AM
YeuEmMaiMai's Avatar
you will toss a cel since the normal cat will not meet the ecu requirements.
Old Jul 22, 2010 | 10:56 AM
Excelerate's Avatar
Former Sponsor
Sometimes the actual housings are different, but most of the time the catalytic core is just larger. If you run a non CA cat you will likely throw a code. You can get rid of the code by running a O2 spacer.
If you are in CT I'd recommend just buying a Random Tech cat and an O2 spacer. It will cost a third of the price of the OE setup:
http://store.excelerateperformance.c.../i-243964.aspx
http://store.excelerateperformance.c.../i-238608.aspx
Old Jul 22, 2010 | 11:16 AM
01tl4tl's Avatar
thanks for the facts Josh
Old Jul 22, 2010 | 12:36 PM
jp75's Avatar
wow thanks guys....i deff be purchasing that
Old Jul 22, 2010 | 07:22 PM
01tl4tl's Avatar
Excelerate is in Ct if I recall- and has a performance shop as well as the parts biz, so you can get it all in one place
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
DerrickW
Nov 15, 2015 05:52 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
