Brake light problems continue...
I had posted about a month ago that my brake light on my dash occasionaly lights up when the emergency brake is not on. It usually only does it when I had the e-brake on, and it stays on after I release the e-brake. I originally thought that it was my emergency brake sticking or not releasing right, and when I brought it to be looked at by my mechanic, he told me that the e-brake was working fine.
Now, the brake light is coming on intermittently at stoplights when I press the brake pedal and it turns off a couple seconds after I accelerate again. I guessed that it was the brake fluid and I checked the level of the brake fluid and it is well above low. My next guess is that it's an ABS problem, but my ABS light is not the one coming on, only the brake light on the dash. My second guess is that it is a bad warning sensor in the brake fluid container.
I really don't want to have to bring it back to Acura. Thanks guys.
Kollage is funn!
1 Post
Originally Posted by alleyesonmeee
Bump!
your brakes work fine though right?....they don't feel weak...?
Well the brakes still work, but they do feel slightly squishy. I'm stumped too...the last two things are the only thing I could think of that it would be since my fluid is very high.
hummm the only thing i could think of is a faulty sensor?
in 1 of 2 places. either the one for the parking brake or the one in the master cyl.
id bring it to any autozone, pepboys type place when its on and see if any code come up (they do free diagnostics)
there's nothing really wrong with mine, but i notice that if i really step hard on the brakes, the light comes on.. and goes away after letting go.. explains why it was on and then off after you accelerated at the stop..
wow batmite a 6 year old thread revival!!!
when brake lamp light comes on- ck each brake light bulb including the center mount ones
Next ck the brake light activation switch - behind the brake pedal arm
likes to come loose- tighten and fixed!
one thing is brake lights, the other is cruise control disconnect
ck res cap- the sliding sendor in it fails and causes intermittant light as fluid moves,
replace cap and flush brake fluid
the cap has been found to fail on many gen2 since this thread was started
35 bucks for a new cap or 85 for a new brake master cyl and cap aftermarket
I went with all new master cyl and cap to match the all new brake calipers and other upgraded brake parts SS lines etc on my 01
make the brakes as best as I could--those parts do wear out
big props for using search feature!! but there is a more current thread on subject~
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
HeloDown
09-08-2015 06:51 PM
