Blitzsafe for IPOD
Old 08-14-2009, 09:23 AM
  #201
2003 TL
webmastir's Avatar
k. just had to make sure
that's pretty lame it doesn't ship w/ the new cable by default
Old 08-14-2009, 10:24 AM
  #202
JM604's Avatar
When I got mine from enfig, everything that was needed came in the package...
Old 08-14-2009, 10:32 AM
  #203
2003 TL
webmastir's Avatar
Even the new(updated) cable?
I just bought mine from enfig too, was cheapest, but it says all over the page(see link at bottom of page 5), that it won't charge new iPhones or 2nd gen ipod touches, which is what I have & want to use with the blitzsafe.
Old 08-14-2009, 01:04 PM
  #204
andrewz182's Avatar
mine stopped working after a few weeks. everytime i have to disassemble the side panels and stuff to tweak the cable a bit to get it to work, and then when i re assemble everything, itll stop working again.
ive gone through this process three times now and i have lost all patience with it.
Old 08-14-2009, 01:07 PM
  #205
2003 TL
webmastir's Avatar
possible loose wire on the harness...?
Old 11-02-2009, 02:26 AM
  #206
Vman159's Avatar
hey any ways guys i have a 2000 tl and i had the disk changer in the trunk but i took it out cause it broke. I have some wire with a blue connector run to where the disk changer was. is that where i need to plug it in or do i plug it into the back of the radio? also is blitzsafe only made for a ipod? cause i have a phone with a 3.5mm input and i was wondering if i would be able to use blitzsafe as aux with my lg chocolate 3?
Old 11-02-2009, 09:28 AM
  #207
is too sexy for his shirt
99AcuraTL03's Avatar
you need to plug it in behind the cd player where the cd changer port is. blitzsafe makes a connector that is universal for all 3.5mm inputs but does not charge like the ipod one. same price though
Old 11-02-2009, 12:05 PM
  #208
Vman159's Avatar
does it usually come with it(connector) or do i buy the connector? i dont really care if it charges or not i just want aux to work with anything that has a 3.5mm inputs
Old 11-02-2009, 01:25 PM
  #209
It's the Halladay season!
hANDYcaptd's Avatar
The Blitzsafe outputs to red and white RCA cables. You have to buy the RCA to 3.5 mm cable. Radio shack has them for like 6-7 bucks.
Old 11-02-2009, 03:11 PM
  #210
Vman159's Avatar
oh i have one that is a red and white one one side and 3.5mm on the other side. will that work?
Old 11-02-2009, 09:57 PM
  #211
if you buy it off of ebay it comes with it
Old 11-03-2009, 12:21 PM
  #212
JasperKeith's Avatar
Red face Blitzsafe install issue
I don't know if anyone else has experienced this, yesterday I installed my Blitzsafe Ipod adaptor in my 2003 TL Type-S w/nav, tested it, everything worked perfectly. Then I tried to reassemble and run my cables back to the console. Somewhere in the process I lost all sound. I still get the digital display on the radio, but no sound, no illumination, no steering wheel control. I checked fuses, they seemed good. If anyone has any idea on where I may have run a ground, I would appreciate any input.
Old 11-03-2009, 02:01 PM
  #213
2003 TL
webmastir's Avatar
Is the wiring harness loose - or any of the wireless going into the main harness?
Old 11-04-2009, 08:07 AM
  #214
I pulled it all out last night, I couldn't find any loose wires in the harness, I made sure they were all plugged in tight to the back of the radio. What doesn't make sense is that I still get the digital display, but lost everything else, illumination, sound, and steering control.
Old 11-04-2009, 02:19 PM
  #215
hANDYcaptd's Avatar
Do you have your radio code? I would try and reset the radio and see if that works.
Old 11-05-2009, 08:27 AM
  #216
I had to put the code in after I disconnected the harnesses, and also after I pulled the fuses to check them, it accepted the code just fine. It actually displays the station, volume level, etc. I can change to FM/AM/CD that all displays. That is what is most perplexing, I see the digital display, but nothing else works.
Old 11-05-2009, 01:53 PM
  #217
Vman159's Avatar
hey guys what is that white wire over with the jack? not the rca but the other one. is that the the one that you can plug into any 3.5mm?
Old 11-06-2009, 12:55 AM
  #218
Vman159's Avatar
that wire on the left is the one i am asking about.. what is it for??
Old 11-06-2009, 08:14 AM
  #219
hANDYcaptd's Avatar
Yea, that's the 3.5mm
Old 11-06-2009, 11:32 PM
  #220
Vman159's Avatar
so do you think that will fit my 00 tl? and the aux plug will work on any thing that has a input right?
Old 11-07-2009, 11:31 AM
  #221
hANDYcaptd's Avatar
It'll work for anything with output. If the Blitzsafe is made for 99-03 TL then yes, it will work.
Old 11-10-2009, 09:19 AM
  #222
Still no luck, I've been without any audio for a week now. I may have to take it into a shop as I run out of ideas as to where the problem may be. Any one else have any ideas?
Old 11-10-2009, 11:29 AM
  #223
bruistopher's Avatar
Can you by this at radio shack or best buy? or do you have to order this online?
Old 11-23-2009, 01:58 PM
  #224
Vman159's Avatar
I have not seen any around at radio shack or best buy. But i would look online or on acurazine BM
Old 11-23-2009, 03:20 PM
  #225
Vman159's Avatar
hey guys any ways received my blitzsafe and i wanted a diy on how to do it cause i already searched but cant find it
Old 11-23-2009, 05:03 PM
  #226
2003 TL
webmastir's Avatar
althought i don't understand much of what you just said or asked, i think you're looking for/wanting this pdf?
http://www.skyeflye.com/acura_cls/In...01-2003_CL.pdf
(just did a search in the audio section of the forums -> https://acurazine.com/forums/audio-video-electronics-navigation-22/ice-link-cl-factory-nav-%3D-yes-pics-instructions-154278/)
Old 12-14-2009, 06:05 AM
  #227
Grandmas drive 3.2TL-S
exel's Avatar
Just recently ordered and installed mine in 15 minutes without removing the radio. Everything is working great! Charges both my iphone3G and my girlfriends 2G as well. Music sounds just as good as a CD.
Old 12-14-2009, 09:15 AM
  #228
2003 TL
webmastir's Avatar
awesome. shit, i think it sounds A LOT better than CDs. I love my iPod touch 2nd gen. I really want to get the mount for it, as shown in that *pdf.
I know I'm going to crash one of these days dicking around with changing songs while having to hold it in one of my hands in stop-n-go traffic
Old 12-14-2009, 10:33 AM
  #229
hANDYcaptd's Avatar
^ lol That's why I love my USASpec. I can still use the steering wheel controls.
Old 12-14-2009, 01:09 PM
  #230
Vman159's Avatar
well blitzsafe does sound amazing i installed it in 20 minutes without removing the cd player also.
Old 09-04-2011, 03:51 PM
  #231
LeolaMax28's Avatar
IPOD Adapter for '99 Acura CL 2.3
Hi!
My name is Maxine, call me Max!.......maybe you have answered this question many times before but, my eyes are a bit tired from searching the forums. I don't know too much about cars and audio. I need to know what I have to buy for my '99 Acura CL 2.3 in order for me to play my IPOD songs; hopefully something cheap? Still has the factory radio!
Thank you in advace for you reply!
Old 01-29-2013, 12:27 PM
  #232
fog80's Avatar
Hey guys,
I just upgraded to the iphone5 and need to upgrade my cable. The blitzsafe website doesnt have a lightening connector cable yet so I'm thinking of going aux because I dont really need it to charge.
Can i just get a rca to 3.5mm cable and plug it in? Also, does anyone have any pictures of how to get behind the radio? Its been years and I dont remember. The only thing I do remember is that I was able to get this installed without taking my radio out.
TLguy42
09-26-2015 11:27 AM
4drviper
09-23-2015 09:00 PM
Vejey Gandier
09-12-2015 08:59 PM
ivegotthenav
09-11-2015 07:51 PM
GEB
07-07-2004 03:22 PM
Quick Reply: Blitzsafe for IPOD
