battery replacement
Old Jan 10, 2007 | 08:53 PM
asloudasitgets's Avatar
battery replacement
i just bought the sears die hard gold battery, and i see that it is a bit samll for the oem box. i was just wondering what size group is our battery?
and is suppose to be smaller than the oem one?
Old Jan 11, 2007 | 12:09 AM
Got_3.2?'s Avatar
i know the optimas are d34 or d34/78
Old Jan 11, 2007 | 01:50 AM
Hondanutty's Avatar
It depends on what you got from Sears.. The battery may be a different group size in order to get enough cold cranking amps for the car or if you got a universal fit (both top and side posts) it could be smaller than the O.E which I believe was a 24 or a 24F. The main thing is to have enough CCA for the car although if you have a stereo or other high load items you might want to go with an optima (you would be suprised the difference it makes in the sound of a stock stereo).
Old Jan 11, 2007 | 12:42 PM
if you read my original post i said i got a seard die hard GOLD.
Old Jan 11, 2007 | 05:24 PM
rjheiss's Avatar
Optima red or yellow? I've heard the yellow recommended for aftermarket stereo systems requiring a lot of power, but how could it affect the stock Bose system?
Old Jan 12, 2007 | 03:58 PM
Hondanutty's Avatar
The battery is able to supply the stereo (stock or aftermarket) with additional "reserve" power when it is needed and the cars electrical system is unable to produce at that time. The battery, due to its design, is able to fill in the needed power so that the base/speakers can draw the maximum current needed. So for example when the volumn is up on a song with a lot of base the battery kicks in with a little extra juice to let it hit at its best. Sorry if that is a little confusing, but it's the best my tired ass mind can do right now. Let me know if you need more clarification -- I'll try to think of something different.
Old Jan 12, 2007 | 04:01 PM
Hondanutty's Avatar
Fine, but the last time I was at Sears Auto they had several different battery group sizes in their Gold level of battery and some were the universal fit. I didn't know which group you had purchased.
Old Jan 12, 2007 | 04:16 PM
BLADE RUNNER's Avatar
02 TLS SSM - Hi Oh Silvr!
My Battery is Smaller
I bought a Costco battery with the stock specs and it was a little smaller. It fit in and I trimmed the stock plastic cover so it would fit. I wouldn't worry.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Phambam12
Sep 6, 2015 06:57 PM
