Anyone know how to remove super glue?
I need to remove the super glue from under the "3.2 TL" . Tried goo off goo gone, etc and nothing works! Any recommendations ?
thanks
thanks
Goblin With A Wrench
When I de-badge the acura badge, i did the following:
1.) parked out in the sun
2.) some hot water
3.) a good shop rag
4.) goof-off
use the hot water to loosen up some of the glue and gunk. using your thumb start peeling off the glue as much as possible, once you see that you cant break off anymore. hold the rag a little below the glue and squirt the goof-off over the glue and try to let it set. then using your thumb (again) start to rub off the gunk, repeat a couple more times till its off, then using hot water again clean off any excess gunk.
NOTE: Goof-Off doesnt work unless it has time to set, specially if its super glue or a strong type of glue. Trust me, I use this makes-me-high wonder clearner all the time........
2.) some hot water
3.) a good shop rag
4.) goof-off
02' 3.2TL-s /w NAVI
acetone will also take away color, kill clear coat, and do other damages,
let goo off sink in. then rub it off.
using turtle soft paste polishing compound (green packaging) really helped me remove that black glue from the car. better than goo off.
I'm Down Right Fierce!
It shouldn't be attached with super glue.. it should be attached with 3M tape.. which should come off with Goo Gone.
If super glue was used to attach the emblems... (although I don't know what kind of idiot would do such a thing) then you can remove the super glue residue with Acetone.
Don't know what acetone is? Well, you can try to go find some at a hardware store, or another store or, go down to your local drug store and go get nail polish remover.
Yup you heard me. Nail Polish Remover.
Lamborghini Aventador FTW
S E L L
mlody
12-04-2019 02:11 PM
ITSJESTER
17
12-06-2018 02:29 AM
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
