another issue with the tl
Old Mar 11, 2006 | 12:23 PM
NYZGREATST's Avatar
Sig Rho's Finest
about 20 minutes ago i was at the ups store and i tried turning on the car after 10 minz inside the store and it wouldnt turn on. it would crank and turn on briefly but then choke out. it choked about 4-5 times before it finally turned on and i still had to push the accelerator a little to get it going. once in reverse and drive it was fine. i came home, parked, turned the car off and re-started with no problem at all. about 20 mins later i had to go out again and i got the same problem. it feels like the car does not want to stay on and just chokes out. this time i got a check engine light flashing and a tcs light on now.
the only thing i have done in the past few days is replace the spark plugs and put in a bottle of fuel cleaner in the empty gas tank. i didnt have a problem until just 20 mins ago. anybody ever experience this or know whats going on? i was supposed to leave for rochester tmw but i dont think ill be going until this thing is fixed
Old Mar 11, 2006 | 01:24 PM
fsttyms1's Avatar
Go get the code read to see what it is.
Old Mar 11, 2006 | 02:04 PM
NYZGREATST's Avatar
Sig Rho's Finest
nobody can do it today. i really need one of those carchip things
Old Mar 11, 2006 | 02:05 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
battery?
Old Mar 11, 2006 | 02:06 PM
fsttyms1's Avatar
No autoparts store nearby?
Old Mar 11, 2006 | 02:07 PM
fsttyms1's Avatar
Originally Posted by Malayalee King
battery?
If its cranking over its not the battery or alternator
Old Mar 11, 2006 | 02:25 PM
ara606's Avatar
What kind of spark plugs did you use?
Might be them plugs?
Old Mar 11, 2006 | 03:22 PM
NYZGREATST's Avatar
Sig Rho's Finest
NGk iridium
Old Mar 11, 2006 | 03:26 PM
optomos's Avatar
I=X - optomos
How long ago did you put the NGK's in? And by all means go to a pepboys or autozone to have the code read. That will give you direction of where you need to look.
Old Mar 11, 2006 | 03:35 PM
ഥഎണഡഏ Fellas Inc.
o, i had this prob like 2 months ago...it would turn over sporadically and then finally it wouldn't.
Old Mar 11, 2006 | 08:55 PM
NYZGREATST's Avatar
Sig Rho's Finest
i waited for 30 secs with the key in the on position. i did a search and apparantly this pumps the fuel line and it turned like normal. wierd as hell. i guess my fuel injectors are dirty? which is weird since i just poured ina bottle of the cleaner.
Old Mar 11, 2006 | 09:41 PM
CL Platano's Avatar
Tristate ViP Crew
I had that problem with my Prelude back in the days with adding the fuel injector cleaner, after adding that the car never rode the same to me.
Old Mar 12, 2006 | 11:46 AM
NYZGREATST's Avatar
Sig Rho's Finest
wow, thats very weird.
Old Mar 12, 2006 | 12:01 PM
bkzjimmy's Avatar
NiGhT rIdEr
i have this problem all the time. when i searched i found it was a dirty EGR and IM. do a search those 2 and youll find the same thing. i still havent fixed but my TCS and CEL came again yesterday.
Old Apr 5, 2006 | 01:12 PM
bdturbo's Avatar
I had the same problem in my turbo civic....the cleaner sometimes chocked the engine...I dont know why just fill your take up again it should run through the lines and be ok.
Old Apr 5, 2006 | 10:48 PM
redbox18's Avatar
I have the same problem with the car choking. But the check engine light doesn't come on so there is no code to check. I've read postings about cleaning the EGR and the IAC Valve. I haven't added any fuel injector cleaners in the past few months.
Old Apr 6, 2006 | 06:19 AM
1st timer's Avatar
UB6IB9
Could be the IACV imo.
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
