air horns
Old Sep 14, 2005 | 10:58 PM
Blazin_TL's Avatar
Registered User
air horns
i bought some hella air horns today.. it comes with a compressor, relay and 2 horns.. i want to hook this horn up to a switch and keep it seperate from my stock horn.. i.e. i want to hit a button and have my air horn go off. can anyone help me out on how to wire this up?? thanks
Old Sep 15, 2005 | 06:03 AM
AcuraTL's Avatar
OG
It comes with a wiring diagram. Just make sure you hook up the relay correctly. But if you do decide to replace your stock horns, the stock wiring has a negative trigger.
Old Sep 15, 2005 | 11:22 AM
TLEXTREME's Avatar
Missing Machismo
search : airhorninator
Old Sep 15, 2005 | 12:07 PM
fsttyms1's Avatar
shoulda got these
https://acurazine.com/forums/showthr...ighlight=horns
Old Sep 15, 2005 | 02:19 PM
TLEXTREME's Avatar
Missing Machismo
thats even better---lol
Old Sep 15, 2005 | 02:26 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
Old Sep 15, 2005 | 02:29 PM
ഥഎണഡഏ Fellas Inc.
blazin --
connect the power from the compressor directly to the positive terminal on the battery.
connect the negative from the compressor to one side of a switch (i'd use a momentary switch -- the kind on ur computer case) and the other side of the switch to a bolt on the car's chassis/body somewhere.
U wont need the relay if u wire it up this way.
Use 12 AWG wire. The momentary switch i got was a little small so bridged some 18 AWG to it instead.
so [12AWG]-[18AWG]-button
good luck
https://acurazine.com/forums/ramblings-12/masturbation-after-marraige-121803/
U
Old Sep 15, 2005 | 06:31 PM
fsttyms1's Avatar
i would actually hook it up to the factory horn,(that way you can use the steering wheel and not fumble for a little button) but put a toggle switch between it so you dont always have to use it.
Old Sep 15, 2005 | 08:29 PM
ഥഎണഡഏ Fellas Inc.
will the toggle engage only one of the horns at a time? idk if i would want both my air horn and stock horn to honk simultaneously.
Biggie_B
May 27, 2025 05:51 PM
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
hashbrown
Sep 29, 2015 12:13 PM
