99TL Stalling Problem
Old Aug 8, 2006 | 08:46 AM
DriveSlow's Avatar
Question 99TL Stalling Problem
My friends 99 TL with 93,000 miles on it is stalling while driving. It happens while accelerating and completely gives out. The "key" or ignition light comes on and she has to put into neutral or park to get it started, which it usually starts right back up. It then does this 2 or 3 more times in the next few minutes, then will drive fine. She had the shift interlock replaced by dealer and it didn't stall again for a few weeks. It is inconsistent, unpredictable and really dangerous. Has anyone else had this problem? Thank you!
Old Aug 8, 2006 | 08:55 AM
fsttyms1's Avatar
sounds like the bad ignition switch.
Old Aug 8, 2006 | 09:15 AM
adamlee05's Avatar
Thread Police Chief
93,000 miles = warranty Get that junk fixed!
Old Aug 8, 2006 | 09:23 AM
03bl AC k CL's Avatar
Oh Hullow
sounds like what happened to my friends 2000... cept at a traffic light we stopped then it turned green and he hit the gas and nothing happened... we had to start it again... im pretty sure he had his transmission replaced shortly after if that helps at all... idk if the problems are related though
Old Aug 8, 2006 | 09:58 AM
fsttyms1's Avatar
And how is that??? the warranty on the car is 50k
Old Aug 8, 2006 | 10:02 AM
fsttyms1's Avatar
No it doesnt sound like a tranny problem. He never said any thing about the thing having rough shifts, slipping between shifts and a hard time or long pause going into gear. The motor stalling while driving or some of the other symptoms wouldnt be tranny.(possibly while coming to a stop) im still waiting for some to use that excuse when a headlilght goes out
Old Aug 8, 2006 | 10:04 AM
Bob_F's Avatar
Could this also be caused by a clogged Idle Air Control Valve (IACV)?
Bob
Old Aug 8, 2006 | 10:32 AM
fsttyms1's Avatar
Bob
Possible. there are many things that would cause it to stall. Being its a 99 and they had a ignition problem/recall i would guess that since the car is just shutting off
Old Aug 8, 2006 | 12:58 PM
DriveSlow's Avatar
She went out for lunch today and the car stalled on her 4 times in a 3-4 mile radius. She also said that the transmission seems to be shifting a little rough.
Old Aug 8, 2006 | 01:04 PM
Bob_F's Avatar
There was a 2002 recall on the ignition switch for the 1999 TLs. If you call Acura on 1-800-382-2238 with the VIN number, they can tell you if that was done.
Bob
Old Aug 8, 2006 | 01:41 PM
fsttyms1's Avatar
that is a saftey issue with it just stalling. Tell her to bring it to the dealer to have it looked at
Old Aug 8, 2006 | 01:54 PM
NSXNEXT's Avatar
When it stalls does he lose the dash lights as well as the power windows? If so it is most definitely the ignition switch. I had the same problem recently.
Old Aug 8, 2006 | 03:24 PM
MikePA's Avatar
Bob
You can also check Owner Link.
Old Aug 8, 2006 | 03:37 PM
Bob_F's Avatar
Yes, that's an excellent suggestion.
I was actually checking on this recall for my 1999 Acura TL this morning but I couldn't immediately remember my Owner Link password. So I called instead.
Bob
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
