60,000 mile tune up - worth it?
The dealer is trying to get me to do the $695 60k tune up. I was planning on an oil change and the tires rotated, but wasn't ready for $700....is this something I should do to keep the car running well?
It's a 2002 tls
thanks
It's a 2002 tls
thanks
Originally Posted by gmac17
Thanks - I was a bit surprised by the $115 platinum plugs..
Originally Posted by NYbsbl04
So just get the tranny fluid changed, and what else. Is that it? I heard changing the tranny fluid can sometimes accelerate the process of the tranny shitting out
What often happens on domestic vehicles and the newer Toyota "U" series units is that a transmission fluid exchange is done at a very high mileage, such as 150K+. The filter/fluid have never been changed before. New fluid cleans up some sludge/varnish buildup, and clogs the filter entirely. Transmission cokes and dies, as there isn't enough fluid flow. If the filter had been changed, then the problem could've been prevented.
But for you, don't worry about it. Just drain/fill with Honda Z1 or Amsoil ATF and call it a day.
I just called Gary Force Acura in the Nashville, TN area and I was quoted a price of $350 for the 60k check up. I think the only thing I need done is the tranny change. They said that is $45. A radiator flush is $70 and an alignment is $89. Do this prices seem pretty fair?
Those prices are reasonable, at least by Nashville standards...
I'd consider draining the radiator only, and refilling with new Honda Type II or Prestone Universal 50/50 Ext. Life Premix at least every 5-yrs given the ease and minimal cost. It's not reliable to test the coolant as you can only measure the concentration and pH. The pH isn't always accurate as you do not know the status of the corrosion inhibitors. A gallon of Prestone 50/50 Ext. Life Premix is about $9.
I just got a quote for the 60k maintenance at Montgomeryville Acura (Montgomeryville, PA...just north of Philly) and it was around $350 as well for an '02 TL-S.
Where are you that its costing $695...and are they doing more than what is scheduled in the manual?
here in Baton Rouge Louisiana they quoted me $500 minus the oil change that i got it done before i reached 60k.
If u dont do this does it void any warranty or some that they can get u later on it and tell u that u didnt do the 60k maintenance?
60000 service
I am due for my 60000 service and i have read about getting the tranny fuild changed. I had the tranny replaced at around 38000 miles. I was wondering if they chage the transmission fluid during tranny replacement. If so do i still need to get the tranny fluid replaced or can i wait a little longer?
cycdaniel
12-17-2019 10:58 AM
asahrts
09-04-2015 05:55 PM
