60,000 mile tune up - worth it?
Old 07-17-2006, 11:44 AM
4th Gear
gmac17's Avatar
The dealer is trying to get me to do the $695 60k tune up. I was planning on an oil change and the tires rotated, but wasn't ready for $700....is this something I should do to keep the car running well?
It's a 2002 tls
thanks
Old 07-17-2006, 11:57 AM
cjde2006's Avatar
No sir.....change tranny fluid if havent done so and no need to replace plugs until 100K
Old 07-17-2006, 11:59 AM
4th Gear
gmac17's Avatar
Thanks - I was a bit surprised by the $115 platinum plugs..
Old 07-17-2006, 03:07 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
the plugs arent needed till 100k. but you will be paying a good price for them. I wouldnt run any thing other than the oem ones though
Old 07-17-2006, 03:19 PM
NYbsbl04's Avatar
So just get the tranny fluid changed, and what else. Is that it? I heard changing the tranny fluid can sometimes accelerate the process of the tranny shitting out
Old 07-17-2006, 10:20 PM
SodaLuvr's Avatar
Not quite true. That scenario is most common with vehicles having a serviceable transmission filter. Hondas do not, as they only have a coarse transmission "screen" filter.
What often happens on domestic vehicles and the newer Toyota "U" series units is that a transmission fluid exchange is done at a very high mileage, such as 150K+. The filter/fluid have never been changed before. New fluid cleans up some sludge/varnish buildup, and clogs the filter entirely. Transmission cokes and dies, as there isn't enough fluid flow. If the filter had been changed, then the problem could've been prevented.
But for you, don't worry about it. Just drain/fill with Honda Z1 or Amsoil ATF and call it a day.
Old 07-18-2006, 08:57 AM
cjde2006's Avatar
and trust me it is a piece of cake to do it. Easier then oil change
Old 07-18-2006, 11:23 AM
SodaLuvr's Avatar
Yep, unless you strip the fill or drain bolt while trying to remove it.
Old 07-18-2006, 01:21 PM
NYbsbl04's Avatar
Is there a write-up to do this tranny oil change?
Old 07-18-2006, 01:26 PM
GreeneggsandHam's Avatar
yes..just do a search. There's a thread with pics also.
Old 07-19-2006, 11:03 AM
topper1296's Avatar
I just called Gary Force Acura in the Nashville, TN area and I was quoted a price of $350 for the 60k check up. I think the only thing I need done is the tranny change. They said that is $45. A radiator flush is $70 and an alignment is $89. Do this prices seem pretty fair?
Old 07-19-2006, 11:08 AM
cjde2006's Avatar
No....you can drain and fill tranny yourself for 25.00, just test antifreeze to see if it is good....if so why change it? And why get an alignment unless you need one
Old 07-19-2006, 11:21 AM
SodaLuvr's Avatar
Those prices are reasonable, at least by Nashville standards...
I'd consider draining the radiator only, and refilling with new Honda Type II or Prestone Universal 50/50 Ext. Life Premix at least every 5-yrs given the ease and minimal cost. It's not reliable to test the coolant as you can only measure the concentration and pH. The pH isn't always accurate as you do not know the status of the corrosion inhibitors. A gallon of Prestone 50/50 Ext. Life Premix is about $9.
Old 07-19-2006, 11:25 AM
fsttyms1's Avatar
i would only do the things that need to be done.alignment isnt one of them if its fine
:side note: my radiator fluid was 200,000 miles old and was fine in my tl.
Old 07-19-2006, 01:08 PM
Monty's Acura's Avatar
I just got a quote for the 60k maintenance at Montgomeryville Acura (Montgomeryville, PA...just north of Philly) and it was around $350 as well for an '02 TL-S.
Where are you that its costing $695...and are they doing more than what is scheduled in the manual?
Old 07-19-2006, 11:32 PM
2001 TL
sheikh3.2TL's Avatar
here in Baton Rouge Louisiana they quoted me $500 minus the oil change that i got it done before i reached 60k.
If u dont do this does it void any warranty or some that they can get u later on it and tell u that u didnt do the 60k maintenance?
Old 07-20-2006, 03:56 AM
MikePA's Avatar
Old 07-20-2006, 07:37 AM
cjde2006's Avatar
nope
Old 07-20-2006, 10:52 AM
2001 TL
aiight thanx
Old 07-20-2006, 02:10 PM
clarky0169's Avatar
service
There charging me $277.67 + tax for the tune-up and I asked about getting my lowering springs installed at the same time and they want $425! F that-
Old 07-22-2006, 06:44 PM
SH-AWD
LeftCorner's Avatar
It's not going to void any warranty. But, if your trans. takes a shit after 100K miles and you go crying to the dealer for them to pay for it, it helps if you've done all your scheduled maintenace. If you're not going to spend the money for upkeep, why should the dealer/Acura spend any money helping you out beyond your warranty period?
Old 07-23-2006, 03:54 PM
4th Gear
gmac17's Avatar
My $600 price was in Manhattan.
It included plugs, all new belts etc.
Old 09-09-2006, 09:18 AM
9th Gear
rakeshreddyr's Avatar
60000 service
I am due for my 60000 service and i have read about getting the tranny fuild changed. I had the tranny replaced at around 38000 miles. I was wondering if they chage the transmission fluid during tranny replacement. If so do i still need to get the tranny fluid replaced or can i wait a little longer?
Old 09-09-2006, 10:41 AM
B A N N E D
S1CK TypeS's Avatar
i was quoted close to $700 by Acura of Executive in CT and i just had my tranny replaced so i dont even need the tranny flush right?
Old 09-09-2006, 10:46 AM
DRINKING HAS A ME PROBLEM
Rpappi's Avatar
just make sure that you record everything and they cant say anything.
Old 09-09-2006, 08:04 PM
NickS's Avatar
There is no "tune-up" @ 60k miles. Look in your owners manual. There are services due but NOT a tune-up.
Old 04-03-2008, 11:01 PM
farrock02@msn.com's Avatar
But will a tune up hurt the car?
Old 04-03-2008, 11:54 PM
acutee's Avatar
Tune up is always good, but may not needed.
cycdaniel
12-17-2019 10:58 AM
iRaw
ILX Photograph Gallery
09-10-2015 12:29 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: 60,000 mile tune up - worth it?
