6-speed swap
6-speed swap
Ok so my 1999 Acura TL has 125,000 miles. The stock tranny does its job but whens its cold it slips a bit. when warmed up its fine. I plan on keeping the car for a while because i got a GREAT deal on it (salvage vehicle because it was abandoned) and what ever money i put into it is what i would have spent on a different car. but to my question, if i bought a wrecked or salvaged accord or cl with good 6 speed tranny would i have all the parts i needed to do the swap or no?
I don't know the answer to your question but here are some additional links to check out from the DIY Thread:
6 Speed Swap/info
6spd conversion on a 2G TL:
Discussion: https://acurazine.com/forums/showthread.php?t=132196
Pics: https://acurazine.com/forums/showthread.php?t=132270
6MTUA5's Swap thread
https://acurazine.com/forums/showthread.php?t=631849
Phees 6 speed Swap thread
https://acurazine.com/forums/showthread.php?t=703784
InspireTL's Swap thread
https://acurazine.com/forums/showthread.php?t=645076
6 Speed Module Thread
https://acurazine.com/forums/showthread.php?t=699063
6spd mods - clutch dampening device bypass, shifter cable bushings:
https://acurazine.com/forums/showthread.php?t=183560
https://acurazine.com/forums/showthread.php?t=184271
Fill Plug on the 6spd (pics and helms scans):
https://acurazine.com/forums/showthread.php?t=188979
DIY 6spd Shifter Bushing:
https://acurazine.com/forums/showt...hifter+bushing
6 Speed Swap/info
well if you found a wrecked CL-6 why wouldnt you get the better engine to go with the trans. Yes you can use your motor but you will need to run the modules to make it work.
xsilverhawkx
09-28-2015 06:51 PM
