Spare tire 2006 RL
Old 02-16-2011, 12:36 PM
backfire's Avatar
Spare tire 2006 RL
Replacing Pax tires with regular tires. I know the spare for the 2006 rl is T155/70D17. Hard item to find. The 2003 MDX spare is T155/90D16. Does anyone know if it will fit the RL. When I do the conversion it looks to be 1/4 inch shorter( I think)
Old 02-16-2011, 01:14 PM
Chas2's Avatar
Do not do it.
You need to maintain exactly the same rolling diameter, because of the AWD, as the other tires you are running. T155/70D17 meets the rolling diameter requirement of the various tire sizes I cited earlier for 17 through 20 inch.
Also, because of the RL's large front brake caliper, there is no reason to think the MDX spare would fit on the RL, because according to others, including my dealer, none of the 2G MDX OEM or OEM accessory wheels fit on the RL. As always, the watch word is try before you buy.
PS. The RL spare wheel is a beautiful alumninum alloy wheel, no steel wheels for this application, painted a bright yellow so you cannot mistake it as a spare!
Old 02-16-2011, 05:05 PM
backfire's Avatar
Thats why the dealer want $500 for the wheel only. Michelin really screwed us
Old 02-16-2011, 05:32 PM
Chas2's Avatar
Search salvage yards (junk yards) for spares, or sometimes ebay. The salvage yards seem to be all networked together and can get you something pretty quickly.
Old 02-16-2011, 08:39 PM
backfire's Avatar
I called all over salvage yards these things are gold. Know where the tire can be bought T155/70D17. i might just bite the bullet and buy a new rim.
Old 02-17-2011, 04:38 PM
Chas2's Avatar
Really?
Just out of curiosity, how much are the spares going for?
Have you tried the internet, also? There are many internet salvage yard dealers.
Old 03-17-2011, 12:57 PM
4th Gear
Quick99TL's Avatar
I have the same problem, replacing PAX on my 06. I just ordered a set of Black Ice Invisio 20". I would have gotten five of them but a regular sized tire will not fit in the spare tray. I couldn't locate a spare either. Looks like I will end up purchasing one. Let me know if you find an extra one anywhere.
Old 03-18-2011, 10:58 AM
rtr
RL owner
rtr's Avatar
the spare tire is over rated. Like i mean dont bother with it i took mine out and if i get a flat i will tow it. And i think most of us have two sets of rims anyway! I have 3 sets
Old 01-12-2012, 06:51 PM
wildwayne's Avatar
i find the spare on ebay salvage yard
130 shipped
Old 01-12-2012, 07:30 PM
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
Almost a year old thread, the spares for our cars are kinda hard to track down.
Old 11-25-2012, 05:09 PM
Cruising in ATL!!
baboya96's Avatar
Originally Posted by Chas2
Do not do it.
i'm looking to purchase an OEM spare tire off 2nd generation MDX. Are you saying it won't fit my 06 RL? Or just front b/c of its larger brake pads?
Old 11-25-2012, 08:50 PM
BDoggPrelude's Avatar
Correct. It will not fit over the RL's front calipers. The tire will also be too big I would think.
Old 11-26-2012, 06:40 AM
lland's Avatar
Keep an eye on eBay. I got one for around $150 shipped. They don't pop up often but hey do. Remember, you'll need a few other things too: Lug nuts for they spare (they're different), hold down bolt for the trunk, a couple of safety stickers if you want to be "compliant," styrofoam spacer, etc.
LL
Old 11-26-2012, 07:06 PM
Cruising in ATL!!
baboya96's Avatar
will it clear rear calipers?
how do you mean tire will be too big?
Old 11-26-2012, 10:08 PM
Yes, it will clear the rear calipers. If you get a flat on the front you could always move one of the rear tires to the front and put the spare on the rear. This would, of course, require double the time to change the tire.
The MDX spare is a 165/80/17 compared to the RL's 155/70/17. There's a chance it could rub. More importantly, being nearly 2 inches larger in overall diameter, it probably won't fit in the spare well in the trunk.
Old 11-27-2012, 02:03 AM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
One bore an inch higher than the others is a scary thought.
Old 02-01-2017, 07:49 PM
mgmny's Avatar
LL
Sorry for the resurrection, but can anyone explain?
Just de-paxed today, and purchased a spare on eBay for $65.
Won't the nuts presently used on the wheel work for the spare when I do a roadside swap?
What's this styrofoam spacer?
Old 02-02-2017, 07:53 AM
oo7spy's Avatar
The PAX wheels and the standard wheels use different kinds of lug nuts. I'm not sure what wheels you bought or what lugs they require, but the spare should really only be used with the standard lugs. If you bought standard lugs for your new wheels, you will be fine.
The styrofoam spacer goes under the trunk floor and keeps the spare from making contact with the chassis as well as keeping it from sliding around. The hold down bolt goes through the styrofoam and anchors the spare the the chassis.
Old 02-02-2017, 08:00 AM
mgmny's Avatar
I bought standard wheels, so i should be OK on that front.
So, it seems like the spacer and hold down bolt probably aren't necessary. I might just throw the spare in my trunk, and leave the current PAX-spare tire setup in there. I haven't put anything in the trunk or opened the trunk in probably 4 months, so i'm thinking i'll be ok. Thanks a ton for the info.
Old 02-02-2017, 08:12 AM
Chas2's Avatar
I would be curious to know if the standard wheel and tire fits in the spare tire well, or if it is too tall and causes the floor cover not to sit properly. Thanks
Old 02-02-2017, 08:15 AM
mgmny's Avatar
So, I purchased a donut spare, not a full, so i won't be able to tell you.
Old 02-03-2017, 09:13 AM
Chas2's Avatar
Got it, thanks. I had purchased a donut spare also under the belief that fullsize wheel and tire would not fit under the floor cover. I do have the spacer and hold down bolt. Makes for a clean install since you have to remove the very different styrofoam insert that comes with the PAX equipped cars, anyway.
In the case of the spare, you do need different lug nuts. Standard wheels use the lug nut with the flat surface with washer style seat, whereas the donut spare use the spherical seat lug nut. The good news is that the PAX wheels use the same lug nut, so you may have 20 of them!
Old 02-06-2017, 10:19 AM
mgmny's Avatar
I'm sure the tire shop took them... shooooooooooooooot.
spoiler900
05-25-2016 10:16 PM
Slow98teg
09-24-2015 07:54 PM
EE4Life
09-11-2015 10:13 PM
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
datadr
09-02-2015 06:46 PM
Quick Reply: Spare tire 2006 RL
