New Tires hitting Wheel Well?
Hello everyone!
I read the sticky for the tire size, and i picked tires that matched, and my local discount tire seemed to "know best" and pick different things than me. Today is the first day I went on the highway with them, and when i went over a couple bumps, it seems as though my wheels might be hitting my wheel wells? That's what it sounds like, anyways.
Here is what I got:
235 /55 R17 99H SL BSW Yokohama YK740 GTX
I know that's not one of the sizes, but the tire shop assured me it'sd be A OK size. What should i do? I can't imagine this is good for my new tires, but it only happened 2x on an off-ramp on my commute, and very briefly. Looking at them on the car, they seem to be quite large for the well, though. If i get a chance, I'll add a photo in a bit.
What should I do? Do I need to take them back? I've probably put 30 miles on them, plus whatever it takes to get them back to the shop, so maybe 50 miles total. Will they take them back? How should I handle this?
Here is what I got:
Go back to them and tell them they done messed up... .. idiots
Show them that calculator and the fact that now you have a large tire in there from stock size. it's funny because some shops will flat out deny your install if you have a different diameter tire (costco does this for sure.)
If they're the ones that suggested it, they should fix it. You may have to escalate the issue.
The following 2 users liked this post by thoiboi:
justnspace (02-06-2017),
projektvertx (02-06-2017)
Here's a photo:
mgmny (02-06-2017)
I almost feel like the shop just didn't want to lose that sale so just found the closest thing that would fit OP and throw it on there.
as you continue to drive and put wear on the tire, the tire will essentially shave down. I would not worry about it, if it only happened twice.
additionally, tires are not uniform, as in...Different brands will be more thicker/wider or may be more narrow depending on brand
it's under the 3% variance...
I'm betting it's the brand of tire, which could be more meaty BUT shouldnt be an issue if he continues to drive. normal driving will "wear" the tire normally shaving off millimetres of the total diameter
that's if he chooses to do nothing but drive!
he has a choice, if he wants to pursue the tire shop or not
well, the thing is...it does fit!
My only concern with not dealing with it is in the off chance that my car is full of people and a full trunk and then it DOES matter... In my 8 months of owning the car i've only ever had a passenger 1x though, so i guess it's not likely that i will be filling the car up anytime soon...
