dvd video
dvd video
has anyone tried installing dvd video to your rl? would there be a problem when it comes warranty after installation? i heard so much about this conversion for other acuras but not for the rl, anyone else attempted for this?
Are you talking about converting the nav screen to dvd video? If so, yes there are warranty implications; however, U.S. law states that the burden of proof lies on the dealer. If you install it and an issue arises down the road, the dealer has to PROVE that your modification caused the problem with the nav system. Keep in mind, if you get one - the plug and play ones require no cutting or splicing of wires - so you can just take it out should an issue arise with the nav system.
It is fairly simple to do. Check out our vendors - one of them sells a plug and play version and should be easy to install - and if you don't want to do it, you can have a reputable shop do it for you.
I have had an aftermarket Rosen unit installed and it works well. I will provide details if you are interested. The only drawback once installed was the fact that it interferes with my rear view mirror line of sight when deployed. It otherwise works great. I understand this is exactly the same for the Infiniti M factory installed units. The unit is mainly for my 2 year old to watch movies and has nothing to do with my front navigation display.
yup, i want to convert the navi screen to dvd video. I want to shut my gf up when we are on long trips. so has any rl owner got this done? wonder if its the same as for the tl? anyone recommend any sf bay area shops who can do a good job on this kind of project?
I don't think any RL owners have done this yet; however, I know several are considering it. Go with the one stingerbtry just mentioned. There is a groupbuy going on right now in the blackmarket for this and shoudl be able to get it at roughly $225 for the plug and play. It seems to be a great unit.
I do not think it does. But, our only option to find out would be to pull out teh HU and check. Wouldn't we need a compatible blitzsafe device anyways? They would have to engineer one specifically for the RL, correct?
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
