Chrome Trunk Trim for Backup Camera?
Old Aug 30, 2012 | 02:39 PM
Sylvain's Avatar
Question Chrome Trunk Trim for Backup Camera?
As can be seen below, psheu has an interesting solution for a backup camera for my 2006 RL that does not require a relocation of the trunk release.
I am trying to find out what product he was talking about and if there is more than one product that would allow that. I picked up the info below from a somewhat old thread and did not (yet) get an answer in that thread. (I thought a separate thread on the chrome trim camera would be appropriate)
Would anyone have more info about that solution or a similar one?
Thanks.
Originally Posted by psheu
the standard backup camera installation for the 06 have the trunk release relocated to the side of the trim.... if you don't have it, that means someone skipped a few steps in installation.... but if you do what i did, use the 07+ chrome trunk trim, you can still retain the center trunk release
Old Aug 31, 2012 | 04:32 AM
psheu's Avatar
Thanks.
I think the dealers pull this part out of the catalog. Try to call parts department at the dealership and ask them for this part. if you have celestial silver, the closest color should be platinum frost in the 07. call the dealer and ask for this part. 07 RL "tech" chrome trunk trim above the license plate.
Old Aug 31, 2012 | 08:12 AM
oo7spy's Avatar
Part number 13.
http://www.oemacuraparts.com/find-pa...E%20LIGHT%20(1)
Old Aug 31, 2012 | 02:25 PM
Sylvain's Avatar
Originally Posted by oo7spy
Thanks to both of you. Do I also need Navtool NavRGB2+HA20?
Old Aug 31, 2012 | 02:44 PM
oo7spy's Avatar
If you are going with an after market camera, then yes. The Acura accessory should come with everything you need, except it may not fit the trim.
This thread may help. https://acurazine.com/forums/2g-rl-2005-2012-76/07-rear-camera-license-trim-844566/
Old Aug 31, 2012 | 03:47 PM
Sylvain's Avatar
This thread may help. https://acurazine.com/forums/showthread.php?t=844566
Thanks for the reference. I am even more puzzled though. The accessory does not come with a camera as far as I can see or does it? If it does come with a camera, will it connect directly to my 2006 nav system? Are you saying that a third party camera might not fit the 07 trim?
Old Aug 31, 2012 | 05:31 PM
HEAVY_RL's Avatar
this thread has the horse before the cart... keep up the good work 007
Old Aug 31, 2012 | 08:04 PM
oo7spy's Avatar
I'm only here to help.
To clarify, there is a backup camera that was installed by the dealer as an accessory. That's what I was referencing and it should have everything you need to install the backup camera. There are also aftermarket cameras that will require a NavTool or TVandNav2Go unit to interface with the nav screen. Either one will surely work with the trim mentioned before.
Old Sep 1, 2012 | 10:26 AM
Sylvain's Avatar
BTW, isn't the horse supposed to be before the cart?
I didn't realize that an 07 camera had to be bought separately from the trim. So, to summarize, for an 06 RL, I would have to get the 07 trim (around $150) and the 07 camera (around $500) and that would plug into my existing 06 nav without the need for anything else, right?
Old Sep 1, 2012 | 04:18 PM
HEAVY_RL's Avatar
I was complimenting him OP. Yes his horse is in the right place
Old Sep 1, 2012 | 04:55 PM
oo7spy's Avatar
I would go this route over an '07 camera. I don't know what the difference is, but this is made for your car.
http://www.oemacuraparts.com/find-pa...RVIEW%20CAMERA
http://www.oemacuraparts.com/find-pa...A%20ATTACHMENT
Old Sep 2, 2012 | 10:17 AM
Sylvain's Avatar
Yes but isn't that the kit that requires the relocation of the trunk release button?
Old Sep 2, 2012 | 12:55 PM
Megatron's Avatar
Yes, that is the "official" kit from Acura (camera and install accessories) for install of the backup camera on the 2006 RL. But as you said, that is also the one that requires relocation of the trunk release. I did this install on my own RL and I can confirm that it includes every last thing you need for the install, down to tie wraps.
I too looked at PSheu's install before doing mine, and I really liked that in his case, you wouldn't have to relocate the trunk release. But after considering that I would have to custom cut and fit the camera location myself and make sure it fits and secures properly, I decided to just stick with the original accessory. It's hard enough to do all the cutting and drilling and screwing with the original kit. It would have been much harder to make sure things are lined up properly with PSheu's method.
In either case, I think if you are going to attempt it, you should get the kit (both part numbers) and then also the 2007 Trim piece so that way you have everything you need to connect it up to make it work. You will have to custom attach the camera somehow... but everything else is included.
Old Sep 2, 2012 | 02:25 PM
oo7spy's Avatar
This.^
That kit is designed for the purpose of relocating the release, but I think it is your best option to make work with the '07 trim. I don't know how you would know all the parts to get from an '07 to make the camera work.
Old Sep 2, 2012 | 03:37 PM
Sylvain's Avatar
This.^
I think I like the 07 solution but I am worried about Megatron's comment. I guess I would have to rely on someone who's done the 07 thing....
Old Sep 2, 2012 | 03:56 PM
oo7spy's Avatar
Either way you have to drill something.
Old Sep 3, 2012 | 10:59 AM
Sylvain's Avatar
Agreed. The 07 solution seemed to be simpler though...
Old Sep 3, 2012 | 11:10 AM
oo7spy's Avatar
Mounting the actual camera to the trim would definitely be easier. However, plugging it in would be a pain in the ass because it wasn't designed for that. I would rather start with all the parts to make it work and then make it fit rather than the other way around.
Old Sep 3, 2012 | 11:47 AM
Megatron's Avatar
I think the 07 solution looks and works better, but I don't know about simpler! If you're thinking it's simpler because you don't have to mess with the trunk release, that will be more than made up for by the complexity of trying to align and secure the camera to a custom location. If you're going to try though, I would definitely get everything you need with the 06 Kit before you start.
Old Sep 3, 2012 | 05:19 PM
oo7spy's Avatar
Is it really a custom location if the trim already has a hole for it?
Old Sep 4, 2012 | 01:39 AM
Megatron's Avatar
Yes, because you still have to drill through the aluminum trunk lid somewhere to get the wire through. There may be a hole in the trim, but I don't believe the camera is solely mounted to the trim. It should be attached to a more solid location like the trunk lid.
Old Sep 4, 2012 | 09:49 AM
oo7spy's Avatar
Got it. Thanks.
Old Sep 5, 2012 | 07:50 PM
Sylvain's Avatar
Psheu?
Psheu can probably tell us more if he actually went through the installation...
Old Sep 5, 2012 | 08:17 PM
oo7spy's Avatar
He's not around much anymore though. Maybe PM him?
Old Sep 5, 2012 | 09:29 PM
HEAVY_RL's Avatar
I would suggest paypal.
Old Sep 5, 2012 | 10:23 PM
oo7spy's Avatar
Thanks . Everyone knows to try that first.
Old Sep 13, 2012 | 05:27 PM
Sylvain's Avatar
Yes, did that, we'll see the next time he comes around...
Old Sep 14, 2012 | 04:05 PM
psheu's Avatar
the 07-tech license plate trim does not come with camera and it is relatively cheap. you just need to match the little bit of the screw plate to your car color. with this installation, u just need to cut one hole and be done with it vs. relocating the trunk opening latch. all i did is match up the opening and cut the hole big enough to fit the camera (on the trunk part about 1/2" X 3/4" square cut). both the 07 and 06 camera will connect directly to the back of the navigation unit. The camera unit is a bit different between them. let me know if you have any question. I've installed that camera ages ago and it is still going strong
Old Sep 14, 2012 | 04:15 PM
psheu's Avatar
I dug up some old msg I send to help a fellow A-Zine member:
gosh, you'll need to remind me of the 'white clip'. I forgot about that one...
as for the wiring, it is IMPARATIVE make sure you put them in right order (otherwise, you r gonna burn/shortout the camera unit)...
as for running the wires, use the wire-lead that came with the kit and run the wire through the pipe hinge of the trunk (after you assemble the wires and the connectors).... not an easy task.... but necessary!
after you run that through, it's a breeze, just connect the connector to the back of the navi dvd rom unit...
also, be careful when cutting the opening in the trunk lid (it's made of aluminum alloy, very easy to mess up)...
- remove the old license plate trim,
- tape up the general cutting area
- put the new one on so you know where the opening is, and use marker to marke the cutting spot.
- now cut with caution, u wanna cut smaller so u have room to cut it bigger if need to.... otherwise, if u cut it too big, there is no way to recover....
- i used the black tard-like urathan rubber to hold the camera in place (even now), u don't need all those screws and metal plates to hold it in place... benefit, natural water sealant, find the perfect angle, and after they bonded, it's like part of the trunk.....
good luck, keep me posted... and send me some pix
Quote:
Originally Posted by yue3759
Cool - I'm looking forward to working on this project this coming up weekend. I have a couple of questions for you -
- you mentioned in other posts that the wiring is kind of weird for the 06 attachment kit using 07 install. what should I watch out for when doing the wiring?
- in our prior communication you said to remove the white clip in the middle of screw on the garnish, what was the reason again?
- any other tips/advice?
thanks!
stan
yep.... these r the right parts.... -J02ZJ is the platnum frost color closest to the silver color RL... the silver is on the underside of the trim so you can't really tell of the color difference
Hi psheu,
I finally got my camera kit and wanted to see if you could confirm if the parts are what you got for yours.
I got the following parts....
- 08B21-SJA-200 (attachment)
- 08A21-6H2-360 (camera)
- 74890-SJA-J02ZJ (garnish)
I got the right parts, right?
Look forward to getting this thing installed.
Old Sep 18, 2012 | 08:50 PM
Sylvain's Avatar
Thank you very much for the detailed follow-up psheu. It is much appreciated. I will look up those parts and find out how it adds up.
Old Sep 22, 2012 | 07:13 AM
Maintenanceman's Avatar
This is how my -07 camera is located.
Old Apr 22, 2013 | 11:59 AM
Sylvain's Avatar
I am now getting ready to start this project and added up the parts:
- 08B21-SJA-200 (attachment) $132
- 08A21-6H2-360 (camera) $239
- 74890-SJA-J02ZJ (garnish) $152
Total: $523 (AcuraPartsWarehouse.com) before shipping, taxes and any other things they may through at me.
This is (still) far from being cheap but if I can do it myself, it is still less expensive than the 2006 solution from the dealership...
Unless there are now other solutions out there?
Old May 7, 2013 | 11:42 AM
Sylvain's Avatar
Question
I've done a bit of reading on the topic and it seems to me that the $300 Navtool + a $100 camera would be cheaper than the option above and likely as good.
Any thoughts on that?
Old May 7, 2013 | 01:18 PM
HEAVY_RL's Avatar
Thats the world I live and I've had no issues.
Old May 8, 2013 | 10:23 AM
EL19's Avatar
Navtool is $200 on ebay and you can get a good camera for $50. We've all used the same one from china.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rhdune16
Sep 28, 2015 11:31 AM
