2006 DIY battery replacement w/o radio codes
Old Mar 17, 2012 | 11:30 PM
steve807's Avatar
I'm starting to plan the battery replacement on my 2006 RL. Bought used, no manuals or radio/navi codes.
Have you ever used one of those external battery devices that you plug into the 12V (cigarette lighter) socket to keep the electronics alive during the battery change ? I expect it would take some extra care to keep the main battery cables insulated or from touching anything during the change out.
Old Mar 17, 2012 | 11:39 PM
oo7spy's Avatar
I have successfully taken the battery out three times without a need for codes, but you will need an extra battery other than the new one. Another car is perfect.
Place jumpers on your terminals and the other cars terminals. Disconnect the terminals from the old battery keeping the jumpers in contact at all times. Swap the battery and reconnect the terminals to the new battery.
If you need to, a dealer can look up the codes with the VIN. It is nice to know in any case. You may be given a bad battery that will randomly die sooner than can be predicted.
Old Mar 19, 2012 | 07:36 AM
steve807's Avatar
I think I found the codes, inside lid of the engine fuse box on a sticker
a short number, over a long alpha-numeric string...
But I like the idea of keeping things powered up during the change out
Old Mar 19, 2012 | 07:43 AM
steve807's Avatar
hmmm
looks like autozone website lists several batt's that fit except most say:
"Caution: Do not use a memory saver on this vehicle"
what's that all about ?
Old Mar 19, 2012 | 07:51 AM
HEAVY_RL's Avatar
A memory savor is usually a cigarette lighter plug with a 9v plugged into it...
I haven't had to do this with my RL but when I replace batteries I loosen the clamps and hook a jump box to it, when I pull the terminals off I keep the jump box connected and move the terminals to the new battery.
The main thing you want to avoid is a surge through the car and/or shorting out the terminals.
Old Mar 19, 2012 | 12:29 PM
oo7spy's Avatar
When you buy a battery, make sure the top is flat with no protrusions other than the terminals. The positive terminal has a large block with a fuse connected that needs to sit flat on the battery top.
Old Mar 19, 2012 | 09:26 PM
MrKev's Avatar
heres what you do..
start the vehicle, remove the battery, and install the new one.
Old Mar 20, 2012 | 07:30 AM
HEAVY_RL's Avatar
I see a blown fuse in your future
Old Mar 20, 2012 | 10:24 AM
oo7spy's Avatar
Originally Posted by MrKev
heres what you do..
start the vehicle, turn off the radio, a/c, and any other possible electronic, remove the battery, and install the new one.
Has anyone done this in an RL? I know there is a 50A fuse connected straight to the battery.
Old Mar 20, 2012 | 10:40 AM
steve807's Avatar
heres what you do..
as they say: "that's not even wrong"
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
HeloDown
Sep 8, 2015 06:51 PM
NSolace
Sep 3, 2015 08:14 PM
