woo hoo first problem
Old Nov 4, 2009 | 02:34 PM
DurgyNess's Avatar
So after a couple days of tinkering with the side view mirrors cause i had not gotten a chance to program the memory for FOB 1 or 2 yet to my settings after getting the car, now the side view mirrors do not go left or right, just up and down!
Old Nov 4, 2009 | 02:36 PM
Blazing GT's Avatar
do you have a 2005?
Old Nov 4, 2009 | 02:39 PM
DurgyNess's Avatar
yep
Old Nov 4, 2009 | 03:36 PM
getakey's Avatar
no real programming required for some settings - just set the mirrors, wheel, seat to your liking and press and hold the #1 or #2 button on the door
Old Nov 4, 2009 | 03:59 PM
getakey's Avatar
regarding my post above, actually may have to hit "mem" button then #1 or #2
I was thinking of my other car
Old Nov 4, 2009 | 04:05 PM
DurgyNess's Avatar
Getakey:
The mirrors do not move left and right now lol, like when you try to adjust they physically do not move. Only up and down work
Old Nov 4, 2009 | 04:17 PM
getakey's Avatar
Originally Posted by DurgyNess
Getakey:
I don't have an answer for that problem, although I have noticed a similar problem when it is very hot outside (<100)
Given time of year, doubt that you have that issue.
I'm suspicous of the switch though since your problem is common to both.
Old Nov 4, 2009 | 05:42 PM
DurgyNess's Avatar
oo nice a switch sounds much cheaper than the motor for the mirror
Old Nov 4, 2009 | 05:44 PM
Blazing GT's Avatar
i hope you have warranty....
Old Nov 4, 2009 | 08:19 PM
wcoy's Avatar
Dealer replaced both outside mirrors in my 05 under warranty.
Old Nov 5, 2009 | 07:52 AM
DurgyNess's Avatar
No warranty, but they started working again last night lol!!
Old Nov 5, 2009 | 08:03 AM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
It sounds like there is a software issue with the multiplex control unit that operated the memory functionality of the mirrors. This is the same actuator that also manages the tilt down functionality of the mirrors.
Unfortunately I do not think it is repairable by a flash memory update. If I remember correctly, there is a TSB out there that instructs the tech to replace the multiplex modules in the doors.
If you are out of warranty, maybe a good faith or labor only fix can be arranged with your dealer?
I would search for the TSB on the tilt down failure and it should have the part numbers for the multiplex modules. You may even be able to replace them yourself.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
