What engine scanner is best to get
Old Feb 3, 2011 | 10:03 PM
skyrader's Avatar
I'm wanting to get an engine scanner to look up any codes and have the ability to reset and clear the codes. Also want to be able to clear and reset AFS errors and others as well, not just engine codes. Does anyone have any suggestions? I'm not sure what language i.e. OBD2? Is this what Acura uses? Rather a novice here but Don't want to pay 75 bucks at the shop every time I get a code. I like to repair what I can when I can.
Any suggestions would be much appreciated.
Old Feb 3, 2011 | 10:24 PM
tnobori1's Avatar
Missing my
I used a generic brand OBDII scanner on my '03 CL. It wasn't mine, so I can't say that it definitely works on the RL, but I can't imagine it wouldn't. Search eBay, they're cheap on there.
Old Feb 4, 2011 | 10:17 AM
rtr's Avatar
rtr
RL owner
Not sure why you would need it??
Old Feb 4, 2011 | 10:26 AM
Megatron's Avatar
The cheapo ones should work for the Check Engine Light reading and clearing, but your problem is going to be the AFS errors. Those diagnostic codes are not part of the generic OBDII code set, so in order to read that system, you'd need the proprietary Honda tool and it's not cheap... at least $2K if you want to get it for yourself.
Old Feb 4, 2011 | 04:43 PM
skyrader's Avatar
Thanks but I found one for 150.00 it does srs, abs, engine and others for Acura Honda. They also make one speciffically for Honda/Acura for about 200.00 but it comes from China so....... That alos reads all codes etc.
Old Feb 5, 2011 | 03:16 AM
Megatron's Avatar
May I ask which one you found that does all this? If they are the ones from China, I would be very careful. 99% of them are fake and don't work properly.
Old Feb 9, 2011 | 03:56 PM
vhdoshi's Avatar
RLX SH²-AWD
what about CarMD ? (www.carmd.com) Is that a good engine scanner ??
Old Feb 10, 2011 | 10:50 AM
rtr's Avatar
rtr
RL owner
and why would you need this??? i can not see anyone using one of these on an RL 2005-2010. The on board ECU is very good
Old Feb 10, 2011 | 07:03 PM
skyrader's Avatar
It is a Autel Maxidiag model JP701 I bought from Amazon
SidhuSaaB
May 30, 2020 12:40 AM
spoiler900
Oct 10, 2015 06:48 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
