Water in Headlight Assembly
Old Dec 8, 2011 | 11:08 AM
elemgee's Avatar
My passenger headlight assembly must have a small crack in it, because after driving in the rain there is some water in it. I thought it would dry out after several days but its still wet in there. Is there any way to dry it out?
Thanks.
Larry
Old Dec 8, 2011 | 01:13 PM
HEAVY_RL's Avatar
Option 1. Bake it, take it apart, fix the crack, clean it, reseal it.
Option 2. Take it out and try to clean it through the bulb hole, it will just fill back up again if its cracked or has a broken seal
Option 3. Buy a new one.
Old Dec 9, 2011 | 05:24 AM
Sniffles's Avatar
If you're opening it, go with clear corners! At least you're killing 2 birds with 1 stone! hahah
Old Dec 9, 2011 | 07:57 AM
EL19's Avatar
Don't let that water sit in there for too long. It will short out your ballast and then you'll need to buy a new one. They arent cheap
Old Dec 9, 2011 | 08:44 PM
elemgee's Avatar
I removed one of the headlight bulbs, and then aimed a small room heater at the lens and its doing a great of removing the condensation. I'll try to seal the small crack and see if that keeps out the water.
Old Dec 11, 2011 | 05:15 PM
sfmarine0311's Avatar
Water in the headlight really sucks. It drove me nuts when both the headlights on my s2000 had condensation in them. I had to cook them both and reseal them. One actually rusted my ballast pretty bad so it's best to fix it immediately before it gets worst. It can also burn out your HID bulbs which cost a good fortune.
Old Dec 12, 2011 | 11:07 PM
23109VC's Avatar
I just noticed my wife's MDX has condensation in ONE headlight... we have the Acura extended warranty... does it cover stuff like this?? i don't see any cracks in our glass.. I can only assume it's teh seal gone bad??
or do they say "headlights" not covered...
Old Dec 13, 2011 | 08:29 AM
EL19's Avatar
Water in the headlight was covered when I took my TL in. they replaced four ballasts before they finally gave me a new headlight
Old Dec 15, 2011 | 09:29 PM
23109VC's Avatar
took the MDX in today, they said there is a leak or some kind of seal problem.. and that it is NOT covered under my Acura extended warranty... great.....
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
