VSS problem
Old Jul 5, 2017 | 12:53 PM
JwapDreams's Avatar
VSS problem
So I recently replaced my output speed shaft sensor because it went bad. I thought this would fix the problem but after driving for a little bit I found out that the cruise control doesn't work and the Speedo jumps.
I then got the p0723 code again . When put into my blue driver OBD2 scanner I get this.
Not sure what exactly the two bottom problems are trying to tell me.
I thought it was referring to a blow fuse but that doesn't seem the case after looking at the diagrams.
Old Jul 13, 2019 | 10:57 PM
Anthony Davis's Avatar
you ever figure out the issue im having this same problem iv replace the sensor with multiple others and nothing iv opened and tranced my wiring all the way to rewiring it. still nothing but a headache
Old Mar 20, 2024 | 09:27 PM
NathanKage04's Avatar
P0723
28811-RJB-000 (pickup washer part #)
I found out you need this specific washer to property gap the sensor inside the tranny housing. Has your old sensor shown any signs of contact such as scarring/scratching on the metal face of the sensor?
omygod711
3G RDX Problems & Fixes
Mar 6, 2026 10:56 AM
jdm free
Aug 2, 2025 05:34 AM
ChicagoRuss19
1G TL (1996-1998)
Jun 2, 2012 03:03 PM
KilLa22
1G TSX Problems & Fixes
Jun 10, 2009 06:04 PM
