my tsx got a problem
Old Mar 7, 2009 | 12:35 AM
KilLa22's Avatar
new owner here, i got a used 04 tsx
first thing is my car have engine light on, my cousin checked it, told me it was the oxygen sensor, so if anyone know how much that's going to cost me and will i be able to do it myself please let me know
second thing is my car have UNSTEADY rpm, when I'm in drive(not moving), neutral, park. it always jumpers around but always below 1000 rpm, i don't know if it because of the oxygen sensor or what else could it be, if anyone have the same problem or know the solutions to it please let me know, thank you
Old Mar 7, 2009 | 08:08 AM
litesout's Avatar
Oliver!!!
The unsteady idle could be the result of a bad O2 sensor. It could be making the engine run too rich or too lean. Either of which could cause a rough idle.
I've seen other threads about O2 sensors going bad, just search for them and they should be able to give you an idea about how tough it is and how much it'll cost to fix.
Old Mar 7, 2009 | 09:29 AM
JTso's Avatar
You need to verify which O2 sensor is bad (primary or secondary) using a scan tool. Then order it online for around $200. You can replace it yourself with a ratchet and an O2 sensor socket. Fix the known problem first. The other problem might go away as a result.
O2 sensor
Old Jun 7, 2009 | 04:58 PM
KilLa22's Avatar
O2 sensor
wow jtso thx u so much, i been trying to find the freakin o2 sensor for around 200 but i couldnt find it, i keep searching and searching and the cheapest i found was like 280 not including shipping
and one more thing do u kno where can i find a cheap engine undercover aka engine splash shield
thx
Old Jun 7, 2009 | 07:10 PM
club_euro2's Avatar
http://curryacuraparts.com/
Old Jun 10, 2009 | 06:04 PM
npolite's Avatar
Also be sure to buy OEM. There have been a lot of issues with getting any aftermarket ones including Bosch.
cycdaniel
Dec 17, 2019 10:58 AM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
mv01
Sep 15, 2015 10:36 AM
IndycarFaster
Sep 11, 2015 02:52 PM
jordanboi
Sep 5, 2015 01:33 AM
