Trunk Won't Stay Open
Old 03-16-2018, 11:26 AM
parlownr's Avatar
The opening assist on my 05 RL trunk has stopped working. I have to lift the trunk by hand, and if I let go it will slam shut. Has anybody had this problem before? Looking at the parts of the trunk, there are left and right stay sets (for just under $100.00 each), or a dynamic trunk damper (for $30.00). Any guesses as to which is bad? Too bad the RL doesn't have exposed struts which would be simple to replace! Once the temperature warms up a bit, I'll have to remove the interior trunk trim to investigate further.
Old 03-16-2018, 09:49 PM
projektvertx's Avatar
There are struts that hold the trunk up at the base of the hinges. Unfortunately you'd have to remove the trunk liner to get to them. Take a look at part #1 in this diagram:
https://www.oemacuraparts.com/auto-p...=08f10sja000r2
Old 03-17-2018, 05:56 PM
parlownr's Avatar
It looks like there may be an additional set of struts that are included with the optional spoiler. I haven't taken out the trunk liner yet, but I don't think my '05 has these struts. Looking at the parts diagram, I only see items 1 and 54 which are "stay set, R trunk open", and "stay set, L trunk open". There is also a "damper, tailgate dynamic", or "damper, trunk dynamic" - item 25. I'm not sure what this part does. Maybe it slows the trunk when closing, just before it completely closes? Once I get the liner out, I'll see what i find.
https://www.oemacuraparts.com/auto-p...unk-lid-1-scat
Old 03-18-2018, 09:31 AM
Fuchfaccio's Avatar
When I ordered my spoiler it came with new struts. My car already had struts already in place. I installed new ones in case they were just for the added weight of the spoiler (all 3 - 4lbs of it. haha).
One side of the strut is bolted into place and the other side snaps in place. I have had the struts unsnap before, so check that. I had a small air compressor in the trunk, and I think it rolled forward and bumped them. it doesn't take much lateral force to pop them in or out.
Old 03-18-2018, 12:59 PM
parlownr's Avatar
The weather cooperated today so i was able to get into the trunk. It didn't take much time or effort to peel back the trunk trim to access the hinge area. Then a 12 mm open end wrench was all it took to remove the struts. It was easier than I thought it would be. I was confused looking at the parts diagram, but the stay sets are indeed just struts. The drawing looks like there is something attached to one end, which confused me. I just placed my order for a new left and right stay set. The price was about $50.00 lower per strut than the dealer.
projektvertx (03-23-2018)
Old 03-18-2018, 01:50 PM
BANNED
restron's Avatar
i never buy parts fprm the dealer its always cheaper online
Old 03-19-2018, 10:57 AM
Fuchfaccio's Avatar
"The drawing looks like there is something attached to one end, which confused me."
This is correct. Mine came with the rear bracket already attached on one end. I could have sent you mine for the cost of shipping but I wanted to make sure I still had them first. Sorry I'm too late.
Old 03-22-2018, 06:35 PM
Acura05rl's Avatar
I’m looking to buying a trunk spoiler. Will I need to get new trunk struts?
Old 03-23-2018, 04:41 AM
parlownr's Avatar
I think the Acura spoiler may come with new (stronger) struts. Even if it doesn't, the original 13 year old struts may need replacement soon. In my case, I noticed that as the struts became worn the trunk became easier to close. Before they failed completely, I could close the trunk with one finger. If you still have to use some effort to close it, you may be OK.
Old 03-23-2018, 06:42 AM
If you buy the Acura A-Spec spoiler, it does come with new struts. I kept those on backup for when my current trunk struts fail. I'm coming on 5 years with the spoiler, and 11 years old since the car is an '07. Luckily mine are still good!
Old 03-23-2018, 11:56 AM
schen72's Avatar
There definitely is damping for the trunk when it opens. I don't think there is any when it closes, but I always take care to not slam it too hard. That entire strut mechanism looks nice.
Old 03-24-2018, 01:25 PM
parlownr's Avatar
I've always been careful when I closed the trunk. Unfortunately, almost everyone else slams it like they're closing the trunk on a '66 Buick! I've always told them that the trunk is aluminum, and they don't have to slam it, but do they listen......???
DopeAcura
4G TL Problems & Fixes
31
02-18-2015 10:47 AM
Bill Cordray
07-14-2012 02:22 PM
swankrl
12-30-2009 09:20 AM
Acura4x
2G CL Problems & Fixes
12-18-2008 07:25 AM
Quick Reply: Trunk Won't Stay Open
