Oem or better replacement suspension manufacturers
Wanted to compile a list of oem quality or better suspension manufacturers.
Few manufacturers that have established a solid reputation of garbage parts
1) mevotec(also sold as pepboys prosteer brand at some point)
Utter garbage and scam. Plenty of threads online to illustrating horrendous quality. These people are scammers. Ball. Joints fail in 2 months
2) Moog used to be good. But now it's garbage. Ball joints are still ancient design steel to steel. Need to lube. Just popped my sway bar links just after a year
Their springs sag within 2 years of normal use
3)AutoZone duralast and Beck and arnley have always been scrap metal
How does FEQ stand compare to oem. Or are there any other quality ball joint manufacturers for Honda or acura
HEAVY_RL (10-08-2019)
projektvertx (10-11-2019)
People say good things about proforged. Generally rated above Moog. Still went with oem because they are 16$ . Proforged 25$
One thing I don't like on oem links is 6mm alen wrench well on the end of the ball joint stud.
I'll just machine oem to fit 16-18mm wrench. I think it's crucial for easy removal later
Fk no!TheyldstroyEvrthing
Anyone knows who manufactures sway bar links for Acura?
Is there a current concensus on best OEM replacement?
The price for the lniks at my dealer is 45$ . Online comparable price is Adelco Prosessional fpr 35 bucks. (Adelco Advantage is 19$ - Anyone know the difference?)
Does that make Adelco the best option?
The only aftermarket sway bar endlinks I’ve ever had a good experience with are made by Proforged. A lot of people in the Jeep community love Proforged parts. I don’t believe they make them for the RL. I would stick with OEM.
RL09 (11-22-2019)
I found front ones for that brand. But no rear ones. I may just go dealer ones indeed. They are not often changed anyway.
Only one link on the right is making noise. Is it generally better to change both, or one only is fine?
Will the left one get used faster coz the right one is newer or doesn't work like that?
RL09 (11-24-2019)
Thank you. 2 it is.
Are the left and right rear links different parts, or the same one?
Thanks! I just noticed the bags had different serial numbers. So I opened them to take pics.
too bad they don’t have a manufacturer stamp on them
Blaze9
06-06-2018 12:43 PM
