OBDII Scanner and/or Dongle
Old Jan 6, 2019 | 02:13 PM
RL09's Avatar
FkNo!TheyRdstroyinEvrting
There are a lot of dongles on there, that you can use with your smartphone app. Seems there's more bluetooth connecting apps on android than ios, which uses wifi.
I'm wondering anyone knows why the difference in price?
While most are between 10 bucks and 25, there is blue driver for 99 (includes app), and there's this:
Amazon Amazon
for 250!!
What's the difference?
Which app (ios and/or android) you guys found can handle good diagnostics, and can go deep into the various component lights (abs, shawd, vsa, afs, etc) as well as Cam sensors, AF sensors, etc. Basically The whole shabang, and diagnise your driving, MPG, etc.
Anyone use them or know which coves it all and is really good?
Old Jan 6, 2019 | 05:13 PM
RL09's Avatar
See like this bitch: https://caristaapp.com/vehicles does advanced diagnostics etc. for BMWs, but not for Acuras, Hondas.. Chevvy.. While on the frontpage, it says its compatible with all of them.
It's compatible to do basic stuff, but advanced diags. no.
Old Jan 6, 2019 | 05:53 PM
schen72's Avatar
I have on of these OBD2 adapters:
Amazon Amazon
And use Torque Pro on android.
Old Jan 6, 2019 | 05:56 PM
RL09's Avatar
Does Torque do full diagnostics, and do VSA normal position memorization, ABS reset, AFS, etc?
Old Jan 6, 2019 | 06:05 PM
RL09's Avatar
Check this out: compatibility list mentions Honda not Acura. But both Toyota & Lexus are up there. Nissan but not infinity, and has brands like Citroen and Peugeot on there.
https://scanneranswers.com/torque-pr...tibility-chart
Makes me wonder if all functionality is available for Acura & Infiniti?
Old Jan 6, 2019 | 08:38 PM
RL09's Avatar
Check this out: https://www.bluedriver.com/news/hond...ed-diagnostics . But this thing is a hundred bucks. Dunno if it does anything more than Torque..
Old Jan 7, 2019 | 08:56 PM
schen72's Avatar
Sorry, don't know. I only used it when I had a failing cat on my 99 TL. I used it to reset the CEL so I'd pass the smog test we have in CA. I do know it shows it a ton of sensors that your car has and you can create all sorts of virtual dashboards to display those values.
Old Jan 7, 2019 | 09:04 PM
schen72's Avatar
Looks pretty slick. But I'm guessing that all the real brains is in the app, where it pulls in data from other databases to assist with troubleshooting. My guess is that their OBDII plug just pulls back data like any other generic OBDII plug, but they probably hard-coded their app to only talk to their particular plug.
Old Jan 7, 2019 | 10:08 PM
RL09's Avatar
Indeed. The plug only works with their app and vice versa.
Old Jan 8, 2019 | 12:45 PM
RL09's Avatar
Can anyone confirm if all wired scanners can do the reset in the video below, and do the wireless scanners, like torque pro do it as well? TIA!
Old Jan 8, 2019 | 06:37 PM
schen72's Avatar
Question
https://www.youtube.com/watch?v=fqToUNuolWU
I don't understand why the guy in the video is trying to accomplish? Is his VSA light on because there is actually something wrong with his VSA system? If so, why would you want to turn off the light? If there isn't anything wrong with his VSA system, maybe he just turned if off (which illuminates the light in the gauge).
Old Jan 8, 2019 | 07:09 PM
RL09's Avatar
no no I don't think he's just turning off a light.
The Triangle is VSA activation indicator. and the VSA light is: VSA system indicator. When the triangle is on, means VSA isn't even active. Which triggers later a VSA light as well once you start driving over a certain speed. So if triangle is on, means VSA is not active.
This happens if you clear codes apparently, in a normal scanner, like 'clear all codes', it somehow also erases the neutral position memorization. Or if you actually replace the VSA control unit, etc.
Remember Vehicle Stability Assist works together with ABS and SHAWD depending if you're accelerating or braking. It's the more advanced alternative to TCS in TLs. So that computer firmware needs to know where to start from, to "stabilize" the car... . See what I mean?
That starting point, is called "neutral position". so the guy in the video placed the car on a flat surface, and did "neutral position" memorization. So that the system can save that 'neutral' point, and work on stabilizing the car after that.
Once that is done, the triangle goes away, means VSA is active. And when you drive, its now working, and the VSA light doesn't come on anymore.
What I wanna know is, like he showed on his scanner, the 'neutral position memorization' option is there, does the torque pro, or similar apps, have that same menu, and that option.
BlueDriver does not.
Old Jan 8, 2019 | 07:13 PM
RL09's Avatar
Old Jan 9, 2019 | 10:39 AM
RL09's Avatar
Now that's a hell of a dongle
Amazon Amazon
Though not gonna happen
Old Jan 9, 2019 | 10:55 AM
RL09's Avatar
This seems a bit pricier than Torque Pro https://www.obdsoftware.net/ But, I'm not sure why,
Both OTech & Torque Pro do not include vehicle specific enhanced diagnostics for Hondas and Acuras. So I'm wondering why otech is pricier...
I'm starting to be inclined to get a wired one instead of a Bluetooth thingy, this one:
Amazon Amazon
Thoughts?
Old Jan 11, 2019 | 09:03 PM
RL09's Avatar
Boy is this hard. It feels like I will have to have a good app, to get good diagnostics, and the wirefree option anytime, and a cable one as well, as bi-directional option seems mainly in wired unless you go for a 400$ + wireless thingy.
anyone use any of these, or recommends any:
Amazon Amazon
This seems excellent for transmission issues that many scanners don't do.
Amazon Amazon
This looks like a beauty, not cheap, it does diagnostics, but unsure if it will do what BlueDriver enhanced diagnostics will.
Amazon Amazon
Affordable, no diagnostics as far as i can tell.
Amazon Amazon
Seems to be best wired thing for trannies.
Amazon Amazon
Review, comparison here: https://www.obdadvisor.com/foxwell-nt630-review/
If only BlueDriver did bi-directional stuff, I wouldn't be going through all this
jeffsaidso
32
Apr 15, 2026 04:16 PM
snakeman2
Nov 4, 2022 06:27 PM
RL09
Jan 6, 2019 08:39 PM
Umari
1/2G MDX (2001-2013)
Jan 2, 2019 05:43 PM
Umar Imran
Dec 29, 2018 07:04 PM
