No A/C in RL. Bypass relay & recharge?
Hello All,
The A/C in my 2005 RL went warm over the course of 3-4 days. The compressor was engaging at start-up a few different time and would continue working until I shut off the car. Now A/C compressor will not turn on, I am assuming this is because of low pressure and no freon. Has anyone had any experience bypassing the relay which would engage the compressor straight from the battery? I had to do this with an older sports car, but I am hesitant to do it in my RL. Once the compressor has engaged I will recharge it. No running compressor means no recharge.
Thank you
Pete
Thank you
Pete
The 2005 A/C I issues have been well documented here. I think the stator is the majority culprit. Many have trouble shooted their issues by directly applying power and documented that as well. The service manual is probably going to a be a good friend in this process.
I checked the RL garage and didn't find much of anything
I was thinking more along the lines of a search, but I'll do it for you.
https://acurazine.com/forums/showthread.php?t=789051
https://acurazine.com/forums/2g-rl-2005-2012-76/potential-solution-ac-problems-05s-06s-500188/
https://acurazine.com/forums/2g-rl-2005-2012-76/c-compressor-help-866941/
https://acurazine.com/forums/2g-rl-2005-2012-76/005-2005-2008-rl-c-hot-air-%2Afix%2A-diy-w-pics-864675/
This is all within the past year. There are many more.
https://acurazine.com/forums/showthread.php?t=500188
https://acurazine.com/forums/showthread.php?t=866941
https://acurazine.com/forums/showthread.php?t=864675
If you determine the problem is the clutch and stator (common issues), I have one I bought that I thought would fix my problem but I ended up replacing the whole unit.
Let me know, I'll save you a few bucks.
Im leaving for south sunday morning... great timing. ugh
"Ohm out" is a quick way of saying to check for the amount of resistance found in the field coil. Unless you feel like going through the service manual yourself, then i would suggest going to the dealer because it sounds like your "repair guy" is not going to save you any money by just throwing a whole compressor at the problem. That is an over-repair in most cases.
Biggie_B
02-26-2017 11:14 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
