Memory seat reset!!!!!
Old Apr 7, 2012 | 08:45 PM
Toppatop's Avatar
I have read every post on this forum including the ones for cl and tl. I have yet to find the solution to my memory seat problem. Before everyone starts posting links to other threads about linking the fob let me tell you IT IS NOT A FOB ISSUE. With that said..,, there is a dealer reset for the memory seat it's something they glhave to do whenever the battery is disconnected I know this because I've done it before, I just can't remember how it's done. PLEASE!!! If anyone knows how to reset the memory seats I would be ever thankful.
Old Apr 7, 2012 | 09:17 PM
oo7spy's Avatar
In the service manual under seats.pdf, there are instructions for removing the seat. Upon reinstallation, it says
Originally Posted by RL Service Manual
Reset the power window control unit (see RESETTING THE POWER WINDOW
CONTROL UNIT ):
Do the steering column position memorization (see STEERING COLUMN POSITION
MEMORIZATION ).
Maybe search these items and try them. I think they may be in the manual too.
Old Apr 9, 2012 | 07:31 AM
Toppatop's Avatar
Read every section of the service manual and nothing on resetting memory seat. Not even after u remove the seats. That is so weird. U would think theyed add a little line in there about resetting the memory after disconnecting the battery and removing the entire seat. Still no resolve......
Old Apr 9, 2012 | 08:28 AM
HEAVY_RL's Avatar
I realize we are focused on resetting the seat, but what are we trying to solve?
Is the seat not moving with the buttons/levers on the side or is it a memory issue?
Also I assume you are getting "welcome driver" message and the steering wheel is telescoping correctly.
Old Apr 9, 2012 | 08:33 AM
oo7spy's Avatar
Originally Posted by oo7spy
In the service manual under seats.pdf, there are instructions for removing the seat. Upon reinstallation, it says...
Old Apr 9, 2012 | 01:01 PM
Toppatop's Avatar
That's correct heavy everything works the back light on the memory seat buttons are lit the buttons are unresponsive and the green lights on the buttons do not light up as they should
Old Apr 9, 2012 | 01:08 PM
getakey's Avatar
I'm confused on the issue
I assume by everything works, that seat controls work.
Have you set the Memory for D1 and D2?
Old Apr 9, 2012 | 01:41 PM
HEAVY_RL's Avatar
If you have properly set the memory buttons, I believe holding them down, and thats not working... I'm sorry to harp my friend, but i still believe your keys arent synched properly or you need a hard reset at the battery.
My last guess is a full battery replacement.
Old Apr 9, 2012 | 01:45 PM
getakey's Avatar
Do your outside mirrors operate correctly?
If the mirror rotates down in reverse, but fails to return to the normal position, the green D1 or D2 button will not light up.
I have this issue on very hot days.
Old Apr 9, 2012 | 04:11 PM
Toppatop's Avatar
Mirrors at both fine they both tilt down as back up. The memory seat unresponsiveness began after removing the battery. I've tried resinking the remote (I only have driver 2 fob) and still no fix.
Old Apr 9, 2012 | 04:14 PM
getakey's Avatar
Just to be clear, you have pushed "memo" button and then #2 button on door with car in park to set the D2 settings
Old Apr 9, 2012 | 04:26 PM
oo7spy's Avatar
Window reset and power steering memorization?
Old Apr 9, 2012 | 05:10 PM
Toppatop's Avatar
Yes I have tried all of those
Old Apr 9, 2012 | 05:56 PM
getakey's Avatar
strange
I believe the following items are controlled through the memory settings:
seat position
outside mirror positions
steering wheel position
radio presets
hvac temps
If you "mess" with any of these items and then press D2, does it change anything, i.e., change mirror position, then press D2 (not memo, then D2, just D2?
I'm wondering if a sensor is bad in mirror, seat, or steering adn system does not think it has correctly restored preferences and therefore green light does not come on
Old Apr 9, 2012 | 07:23 PM
Toppatop's Avatar
The steering wheel goes up and down when i turn the vehicle on and off but if I move the mirrors they dont move back to the memory set location. when I change the radio stations and presetts they dont revert back to driver #2 settings so imassuming theres somthing wrong with the memory module ...whatever that is.
Old Apr 9, 2012 | 08:54 PM
HEAVY_RL's Avatar
This is has gotten to complicated to not be something simple.
If you dont have two fobs the stations and AC temps wont change because they remember the last setting... but if you set the memory properly (the green light is lit) then you change the seat or the steering wheel (the green light goes off) THEN leave the car and LOCK it... Unlock it and enter the car the seat or steering wheel will go back.
If you do not exit, lock, and unlock the car it will not reset.
Old May 4, 2012 | 09:56 PM
oo7spy's Avatar
For completeness of the thread, I found the steering column reset procedure.
Originally Posted by RL Service Manual, Steering.pdf
STEERING COLUMN POSITION MEMORIZATION
To reset the system when the auto tilt and telescopic feature is turned on ('05 model)
1. Push the ignition switch for at least 2 seconds and release it, or insert the built-in key into the ignition
switch, and remove it.
2. The steering wheel automatically moves fully in and up to let you know the system is reset.
If steering wheel does not move automatically, go to step 3.
3. Move the steering wheel to the highest position and hold that position by pushing and holding the
adjustment button for at least 2 seconds.
4. Then, move the steering wheel to the most inward position, and hold that position by pushing and
holding the adjustment button for at least 2 seconds.
To reset the system when the auto tilt and telescopic feature is turned off ('05 model)
1. Move the steering wheel to the highest position and hold that position by pushing and holding the
2. Then, move the steering wheel to the most inward position, and hold that position by pushing and
To reset the system
('06-08 models)
And the window reset.
Originally Posted by RL Service Manual, Power Windows.pdf
1. Turn the ignition switch ON (II).
2. Move the window all the way down by using the window DOWN switch.
3. Open the driver's door.
4. Do the following 3 times before going to step 5:
-Turn the ignition switch OFF.
-Push and hold the window DOWN switch.
-Turn the ignition switch ON (II).
-Release the window DOWN switch.
5. Confirm that AUTO UP no longer works. If AUTO UP still works, go back to step 1.
6. Move the window ail the way down using the window DOWN switch.
7. Pull up and hold the window UP switch until the window is all the way up, then continue to hold the
switch for 1 second.
8. Confirm that the power window control unit is reset by using the window AUTO UP and AUTO
DOWN function.
Old May 23, 2012 | 11:59 PM
Toppatop's Avatar
I don't know what kind of bug is in the memory seat system but today i got my vehicle tinted and the guys at the tint shop moved my drivers seat. when i got the car back I reclined the seat back and pressed my memory 2 button and vualla !!!! it now works. this isn't really a solution but i figured moving the seat both bottom and the back rest and then pressing one of the buttons might bring it back to its setting position......worth a try
Old May 24, 2012 | 01:07 AM
ichi d's Avatar
U see folks, 2008 models have their share of problems too. lol
Old May 24, 2012 | 11:58 AM
oo7spy's Avatar
:ibusererrorcausedissuemorethancargremlins:
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
