keyless entry issues
Old Nov 17, 2016 | 12:08 AM
fuzzysig's Avatar
when I push the door handle sometimes it unlocks.
sometimes it locks instead of unlocking
sometimes I stand there for about 30 seconds trying to get it to unlock but it locks instead and I end up just using the keyfob.
once in a while it says the keyfob is not detected but the car starts and runs.
is there some kind of issue with the keyless system in this car
batteries are good in the keyfob and I only have keyfob #2 left. don't have the driver keyfob anymore
is there settings for this in the nav system to open all doors with the door handle also?
sometimes I have a passenger and he has to wait for me to open the door and press the unlock manually
Old Nov 17, 2016 | 12:19 AM
RL_Coastin's Avatar
Make sure your key fob is not near your cellphone, your phone will interfere with the key fobs signal. If you have a 2005, they are notorious for having handle issues, some 2006s as well.
For entry settings, you will find those in the MID display. I believe you have to be in park and hold the select button on your steering wheel for a few seconds and the menu will pop up.
Old Nov 17, 2016 | 07:33 AM
RL09's Avatar
FkNo!TheyRdstroyinEvrting
https://acurazine.com/forums/second-...roblem-728104/
https://acurazine.com/forums/second-...roblem-924750/
https://acurazine.com/forums/second-...system-871397/
Old Nov 17, 2016 | 08:07 AM
oo7spy's Avatar
You don't have to push anything. The lock sensor is the "bubble" on the outside of the handle. The unlock sensor is on the inside of the handle. If you grab the handle and put your thumb on the bubble, the car may not know what you are trying to do.
M also, as Coastin said, a lot of things can cause interference. Is the fob near a cell phone? Is a power charger or inverter plugged into the car?
Old Nov 17, 2016 | 11:23 AM
fuzzysig's Avatar
lol ok I found the bubble and was pushing it at the same time as grabbing the handle.
haha that explains alot
Old Nov 17, 2016 | 02:01 PM
RL_Coastin's Avatar
Wow didn't event catch that lmao.
Ron206
2G RDX Problems & Fixes
Oct 11, 2016 01:33 PM
Nemowuner
May 19, 2016 05:53 PM
Superunknown
Apr 4, 2016 04:51 PM
Superunknown
Mar 9, 2016 11:01 PM
nscheid
Jan 19, 2016 09:54 PM
