Keyless entry system delay
Old May 19, 2016 | 05:12 PM
Nemowuner's Avatar
Good day folks.
2007 TL-S
I have to press the remote 700 times before the doors with lock or unlock. Once it starts working it's good for a little while. Any ideas ??
Old May 19, 2016 | 05:13 PM
Have you replaced your battery..
Old May 19, 2016 | 05:14 PM
Nemowuner's Avatar
Yes sir. On both remotes.
Old May 19, 2016 | 05:15 PM
Okay, just wanted to make sure the obvious was covered
Old May 19, 2016 | 05:47 PM
Will Y.'s Avatar
Registered but harmless
How is the car battery? If it's more than three years old, I'd suspect that was a problem.
Otherwise, sit in the car and use the door lock button to see if any of the doors is slower in unlocking than the other. If one is slow, that shows an actuator is going bad.
A final unpleasant thought is that the MICU is problematic, or might have some water in it or gotten wet.
Welcome to AZ.
Old May 19, 2016 | 05:53 PM
Nemowuner's Avatar
Welcome to AZ.
Battery is a year old. I'll have to check the actuators. I was suspecting the MICU but I can deal with it for now. If some other symptoms start to rise I'll have to replace it. I just got the car a month ago and I'm trying to work out all the kinks
gavriil
Apr 1, 2026 12:45 PM
00TL-P3.2
Feb 11, 2019 11:23 AM
TSX69
3G RLX Audio, Bluetooth, Electronics & Navigation
94
Sep 17, 2018 07:45 PM
Superunknown
Mar 9, 2016 11:01 PM
gemz_acura
4G TL Problems & Fixes
Jan 18, 2016 04:41 PM
