How is water getting into my trunk??
Old Oct 5, 2021 | 06:17 AM
Walfunk's Avatar
Angry How is water getting into my trunk??
I have replaced the rubber seal between the rear window and front of trunk lid. Water is still getting into the trunk somehow. Any help is appreciated. Thank you.
Old Oct 5, 2021 | 06:19 AM
through sunroof? through tail lights?
take water hose and run it over the top of the car and trunk lid to find the leak
Old Oct 5, 2021 | 06:48 AM
Walfunk's Avatar
No evidence of water via sunroof or tailights....when I open the truck water drains out of the hinge hole and the upper carpet....
Old Oct 5, 2021 | 07:06 AM
remove the carpet and keep investigating.
Old Oct 5, 2021 | 09:03 AM
deepa1600's Avatar
There is a rubber seal around the hinge pipe where it attaches to the trunk lid pipe and another seal around hinge pipe which goes into the trunk. Those two seals get deformed overtime and don't close properly therefore water gets in the trunk when it rains. What i did was applied black silicone bead (sort of like very small sreing) on top of the seals and let it ary dry with the teunk open. Otherway of fixing it is to remove the trunk lid and replace those hinge pipes or seals. I think THIS is the part you need.
Old Oct 5, 2021 | 10:43 AM
Walfunk's Avatar
man, thanks soooo much for this! Much appreciated!! Will check it out.
Old Oct 7, 2021 | 03:15 PM
KB1's Avatar
KB1
Deepa is right .. had this issues before on my 06.
Old Oct 11, 2021 | 07:04 PM
altair47's Avatar
There is one surest way to check where it is leaking from. Disassemble the trunk side trims, take out the floor and spare tire (about 10-20 minutes of labor). Get into the trunk with a flashlight, close the trunk and ask someone to wash the car with a pressure washer and look from where the water leaking.
Old Oct 13, 2021 | 11:21 AM
Littleme's Avatar
5th Gear
Make sure tailllight wire boot is pointed up, water can run thru and out if pointed down. For me it was the trim piece on each side between hinges and taillights. Its secured by two plastic push in connectors that have openings at the end. One of each is exposed in trunk other of each is out of sight but caulking tip or finger will reach. I just sealed em up and may hafta go over one again but my trunks dry on right and left is 99%. Think i can put all the trim back now! Hope it helps you.
Petahhbread
ILX
Dec 26, 2015 01:26 AM
fern1
Mar 31, 2009 11:30 PM
Renegade
Jul 3, 2008 12:25 PM
3.2CL-sEx
Jan 27, 2008 01:36 AM
lenjaiah
Oct 15, 2007 01:45 PM
