car won't start
Old Mar 8, 2010 | 07:45 AM
dep378's Avatar
2005 RL
car won't start
I replaced all the bulbs in my a/c unit yesterday & now the car won't start. Has anyone else had this issue when doing that? The seat won't even move & the gear shift in lock mode. I tried jumping it off, but nothing. What's the deal. What have I done?
Old Mar 8, 2010 | 02:24 PM
Dopes6070's Avatar
Its probably a dead battery. Did you maybe leave the ignition switch in the "1" position? I don't think replacing the lamps for the A/C is related to the car not starting.
Connect a volt meter to the battery terminals and it should be over 12v.
Old Mar 8, 2010 | 03:36 PM
dep378's Avatar
2005 RL
I'll try that. After I worked on it I tested it & the defrost light was flashing & then the auto & dual lights flashed together when I pressed auto, so I thought I did something wrong. I did leave the ignition on for the radio & the door open for a breeze(it was actually warm out), but I didn't thing that would run the battery down that bad. Thanks.
Old Mar 8, 2010 | 04:25 PM
getakey's Avatar
sounds to me like you created a short somewhere
As I recall there is a main fuse for the battery located on the positive cable connection. You may have blown that fuse.
Old Mar 8, 2010 | 04:29 PM
nore03's Avatar
Randy is the Future
I'd assume a dead battery. Last week while changing my breaks i carelessly left the car in acc 1 and had the radio on and door open and my car died. So just have someone give you a jump. I'd think that should solve it.
Old Mar 8, 2010 | 06:14 PM
neuronbob's Avatar
Yet more evidence that our OEM batteries are weak sauce. I propose that Acura fit RLs with deep cycle batteries given the amount of electronics in the car.
Old Mar 8, 2010 | 06:19 PM
getakey's Avatar
if its the original 2005 battery, then its probably overdue for replacement
Old Mar 10, 2010 | 07:40 AM
dep378's Avatar
2005 RL
The battery charger worked & all the a/c lights work now. Does anyone know what bulb the heated seat light uses? My low light is out & while I still have everything apart, I figured I would replace it too.
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
