Brakes
Old Aug 22, 2013 | 07:11 PM
Andrew/RL's Avatar
Brakes
I need new pads and rotors up front, I was thinking of cross drilled rotors but not sure if it makes a difference or is it just for looks. Any suggestions?
Old Aug 22, 2013 | 09:50 PM
BDoggPrelude's Avatar
Just for looks really, unless you're taking it to the track. Theoretically, when it comes to normal street driving, having cross drilled rotors are going will actually decrease the rotor surface area for the pads to bite down on. Cross drilled/slotted rotors are only beneficial under conditions that require repeated threshold braking stops.
Yes, some people are going to come on here and swear up and down that their cross drilled rotors made a huge difference in their stopping distances blah blah blah. Brakes are kind of like tires in the sense that most people only replace them when needed. When you replace worn ass pads and rotors with brand new parts you are going to notice a difference regardless of quality, construction, etc.
Old Aug 23, 2013 | 12:15 PM
rlerman's Avatar
I use centrics w/akebono pads No issues. Pure street driving and I'm not hard on brakes. Still have original front rotors with 92k miles. Replaced rears with centrics earlier this year.
Old Aug 23, 2013 | 06:47 PM
Andrew/RL's Avatar
The rotors are warped, that's why I need to replace them, I'll probably just get a good set of rotors and ceramic pads. Thanks for the replies
Old Aug 23, 2013 | 07:13 PM
I too have the Centric rotors. Great OEM replacement and come with their anti-corrossion e-coating.
Old Aug 23, 2013 | 07:17 PM
Andrew/RL's Avatar
I was looking at those on tire rack, I am going to order a set thanks for the recommendation
Old Aug 24, 2013 | 01:53 PM
rlerman's Avatar
They are cheaper on amazon I think, or they used to be.
Old Jan 17, 2014 | 11:41 AM
rlerman's Avatar
Just picked up a set of front centrics on eBay, $38 each! I feel the brakes pulsating at hwy speeds so I'm thinking they are a little warped. Hope fronts are as easy as the rears were. I suspect they are, really just two bolts holding caliper on and the screw on the rotor.
Ill be doing brake fluid flush too, been about three years and pedal feels a little softer lately.
Fun weekend ahead!
On Monday, new tires going on, Versados!
Old Jan 17, 2014 | 12:42 PM
oo7spy's Avatar
Old Jan 17, 2014 | 05:02 PM
HEAVY_RL's Avatar
I shut down at the first 12 words.
Old Jan 17, 2014 | 06:17 PM
rlerman's Avatar
Tough crowd!
Old Jan 17, 2014 | 09:43 PM
oo7spy's Avatar
Sorry, man. Not to kill your buzz but there are certain things I don't chance eBay discount reliability on, and safety features dominate that list.
Old Jan 17, 2014 | 11:54 PM
wackjum's Avatar
Usually "warped rotors" is due to uneven pad deposits.
Old Jan 18, 2014 | 04:36 AM
DanL07RL's Avatar
ABSOLUTELY!! There are those who will tell you rotors don't warp. Before you change them, do a run out test with a measuring device. Then you probably can clean the rotors by running strongly abrasive pads for a few miles, then replace those with OEM pads and bed them in properly.
See here: http://www.stoptech.com/technical-su...nd-other-myths
Porsche guys deal with this all the time......just sayin'.
Old Jan 18, 2014 | 12:13 PM
rlerman's Avatar
All done. There were some decent grooves on the insides of the rotors even though outside looked ok. Easy job, took about 2 hours, including brake fluid flush on all four corners, fluid was very dirty.
On the rotors, they seem pretty good to me. Markings match Centric specs and are etched into the sides. They seem authentic. We'll see. Car stops a bit better, but I bet more has to do with the fluid than rotors. I didn't replace the pads as they are relatively new.
Old Jan 19, 2014 | 02:10 PM
HEAVY_RL's Avatar
yea fluid makes a big difference.
Old Jan 20, 2014 | 01:35 PM
rlerman's Avatar
Did some highway driving today, all pulsating that I felt while brake at 60-75 is now completely gone. New rotors have made a huge difference. I went 95k mile on the originals, prob should have changed them 10k miles ago.
Old Jan 20, 2014 | 02:32 PM
oo7spy's Avatar
Did you ever have them resurfaced?
Old Jan 20, 2014 | 03:07 PM
rlerman's Avatar
No. I usually replace rotors rather than resurface. They aren't that expensive.
Old Jan 20, 2014 | 09:11 PM
oo7spy's Avatar
You went 95k mi on one set of pads?
Old Jan 21, 2014 | 06:25 AM
rlerman's Avatar
No, only rotors were original. I'm on my second aet of pads. The car sees no city driving, only hwy and suburban, and I'm not heavy on the brakes.
Old Jan 21, 2014 | 06:37 AM
DanL07RL's Avatar
I went 90K on one set of original pads....possible if you take care of the car.
Those new rotors and pads need to be bedded in....see the article I posted. Not hard to do but nececssary. Just sayin'.
Old Jan 21, 2014 | 08:15 AM
rlerman's Avatar
I think bedding is more critical for the pads than the disc, and mainly for race applications. I think it's less critical for the street as the compounds are different. Since I only replaced the discs, I'm not too concerned with bedding.
Old Jan 29, 2014 | 07:41 PM
RL-SK8's Avatar
Hi guys !
What do you think about OEM rotors pads fornt and rear?
Are they same quality as after market.
Please help.
Acura RL 2008 71000miles.
thanks
Old Jan 30, 2014 | 07:57 AM
HEAVY_RL's Avatar
Thats a tough question, my car has done fantastic with the brake wear at over 100k on the original rotors. So I would probably go back OEM.
But there are a LOT of factors including the driving style.
Old Jan 30, 2014 | 03:23 PM
oo7spy's Avatar
This could be your problem. You should resurface your rotors before putting on new pads.
Old Jan 30, 2014 | 04:48 PM
rlerman's Avatar
My first set of pads lasted 80k miles and my front rotors went 95k. I'd call that very good wear. What problem are you referring to?
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
