auto headlights not working
Old Mar 25, 2012 | 08:16 PM
bronx1480's Avatar
So when i purchased the car in may 2011 i was driving on the highway and it was almost dark and the headlights came on. At first i had no clue what was going on until i looked in the manual and found out it was normal. Ever since then i have tried numerous times to adjust the settings to auto and i can't seem to get the lights to come on. Is there a diagram so i can see if i have it in the right slot. Idk i guessn im going to have to take it to the dealer hopefully the warranty covers it
Old Mar 25, 2012 | 10:41 PM
oo7spy's Avatar
2005? There seems to be some quirks in the '05 Auto system.
Old Mar 25, 2012 | 11:04 PM
HEAVY_RL's Avatar
Here we go with the o5 "quirks"
What do you mean in the right slot? either the switch is in off, auto, parking, or headlights.
Do you have any stickers/tint on your windshield?
Old Mar 25, 2012 | 11:45 PM
bronx1480's Avatar
I have a 2007 and no i dont have any tints or anything blocking the sensor.
Old Mar 26, 2012 | 08:09 AM
HEAVY_RL's Avatar
Sorry the 05 thing was for 007... you missed the "what do you mean by slot" question.
Old Mar 26, 2012 | 08:34 AM
bronx1480's Avatar
Sorry maybe i used the wrong term but all i was trying to say was i had auto lined up on the turn signal lever the correct way. If that makes any sense at this point lol
Old Mar 26, 2012 | 09:10 AM
HEAVY_RL's Avatar
Yep makes, sense... have you adjusted the auto light settings in the MID?
Old Mar 26, 2012 | 09:32 AM
bronx1480's Avatar
Yes i did that too. Is there some sort of diagram that i can see if i have it lined up correctly?
Old Mar 26, 2012 | 09:52 AM
HEAVY_RL's Avatar
Thats where you lose me bro... what are you lining up?
If the switch is in Auto, and the MID is set to the right sensitivity and it gets dark or you pull in a garage your lights should come on.
If not, and you turn your switch to the "on" position and the lights work, then you have a problem.
Old Mar 26, 2012 | 10:03 AM
oo7spy's Avatar
Don't call him "bro".
I was referring to the headlight notification upon turning the car off with the lights on "auto" in the 2005. That's the only model that does it.
I have seen other threads that claim the exact same thing. I agree that the sensitivity settings are not exactly intuitive. Bronx, what if you put a sheet of paper over the sensor? Do the light's turn on? It is in the middle of the dash behind the center speaker.
Old Mar 26, 2012 | 10:04 AM
bronx1480's Avatar
Auto on the headlight lever
Old Mar 26, 2012 | 10:11 AM
HEAVY_RL's Avatar
My bad. Brah.
Old Mar 26, 2012 | 10:15 AM
oo7spy's Avatar
There is no special technique to lining it up. If you think it is, I am sure it is. There are four notches that you can feel as you turn it. Auto is the third one from the top. Try the paper thing and report back.
Old Mar 26, 2012 | 10:24 AM
HEAVY_RL's Avatar
There is also a visual referece
In the top left corner of this pic, you see "off" "parking" "auto" "on"
Old Mar 26, 2012 | 12:26 PM
bronx1480's Avatar
Lol u guys are hilarious but yea thats exactly how i had it set up and in the mid setting i hadvit on high and it still didnt come on. Im going to try that paper scenario tonite when i pull into my garage. If thatvdiesnt work do you guys think i will have to come out of pocket if i take it to the dealer ? Im still under warranty until 100k
Old Mar 26, 2012 | 12:30 PM
HEAVY_RL's Avatar
If you are under warranty, I would call and make an appointment and let them look at it.
I wouldn't expect you to come out of pocket unless you did something.
Old Mar 26, 2012 | 01:54 PM
oo7spy's Avatar
^Yes. That is a pretty crucial function. If covering the sensor doesn't trigger the lights, I would think the system is messed up somewhere between the fuse and the sensor.
Old Mar 28, 2012 | 10:01 AM
bronx1480's Avatar
I happen to go through a tunnel and i tried the auto setting and it actually worked this time. I was in totally shock. I still made a appt with the dealership for monday and i have a loaner car reserved for me. Could it be that maybe the sensor went bad and thats why it didn't work?
Old Mar 28, 2012 | 10:22 AM
oo7spy's Avatar
It could be you have the sensitivity set to the wrong extreme.
Old Mar 28, 2012 | 11:32 AM
bronx1480's Avatar
Tried the different settings earlier and it wasnt working
Im going to try it again before i take it in to the dealership.
Old Mar 28, 2012 | 11:56 AM
db22's Avatar
I think that it is caused by the tints on your rear lights.
Old Mar 28, 2012 | 12:13 PM
bronx1480's Avatar
How so ?
Old Mar 28, 2012 | 12:34 PM
HEAVY_RL's Avatar
Old Mar 28, 2012 | 12:35 PM
HEAVY_RL's Avatar
Old Mar 28, 2012 | 01:28 PM
oo7spy's Avatar
I'm going to go out on a limb and guess db doesn't like your taillights or fabrication of the word "tints".
Old Mar 31, 2012 | 10:48 AM
bronx1480's Avatar
maybe so
TLrascal
Aug 3, 2018 11:00 PM
acurajj
Sep 19, 2015 03:47 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
