Another Keyless Entry Problem
I have had my 06 RL for 2 or 3 mo now and really like it. Had some problems with the pass door handle - it was intermittent and did not work when the humidity was high. They replaced it and all is good.
The other problem is the ignition lock. I am keeping count and I have had to pry the plastic thingy that you turn instead of a key off and use the key to start the car. Any idea as to what the problem is? I know that when I take it to the dealer it will work fine!
steering wheel locking
I have had that problem from time to time and have finally figured out that it happens more often when the wheels are cocked when I turn the car off. If the steering wheel isn't close to being strait up, it happens.
Agreed. I have seen this on my RL try turning the wheel. This happens with my Mazda as well.
I have the exact same issue.
I thought my steering wheel was "cocked" when I couldnt turn the ignition.
I have to really muscle the ignition switch to start about 70% of the time.
I live an hour away from my Acura dealer, so I'm hoping there's a quick fix (yea, right).
I still LOVE my car though! Actually this has been the ONLY issue I've had.
SidhuSaaB
05-30-2020 12:40 AM
