Another Keyless Entry Problem
Old May 24, 2009 | 07:38 AM
myronf's Avatar
I have had my 06 RL for 2 or 3 mo now and really like it. Had some problems with the pass door handle - it was intermittent and did not work when the humidity was high. They replaced it and all is good.
The other problem is the ignition lock. I am keeping count and I have had to pry the plastic thingy that you turn instead of a key off and use the key to start the car. Any idea as to what the problem is? I know that when I take it to the dealer it will work fine!
Old May 24, 2009 | 09:01 AM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
The battery in your remote might be weak, although if that were the case you should see a message in the MID.
Old May 24, 2009 | 09:20 AM
myronf's Avatar
no, it's a new battery
Old May 29, 2009 | 10:11 AM
bearingman07936's Avatar
steering wheel locking
I have had that problem from time to time and have finally figured out that it happens more often when the wheels are cocked when I turn the car off. If the steering wheel isn't close to being strait up, it happens.
Old May 29, 2009 | 10:15 AM
jfarabaugh's Avatar
Agreed. I have seen this on my RL try turning the wheel. This happens with my Mazda as well.
Old May 29, 2009 | 07:28 PM
myronf's Avatar
I have tried turning the wheel, and that's not the problem. Works fine when you use the key.
Old May 29, 2009 | 07:50 PM
woodek's Avatar
I have the exact same issue.
I thought my steering wheel was "cocked" when I couldnt turn the ignition.
I have to really muscle the ignition switch to start about 70% of the time.
I live an hour away from my Acura dealer, so I'm hoping there's a quick fix (yea, right).
I still LOVE my car though! Actually this has been the ONLY issue I've had.
Old May 30, 2009 | 06:36 AM
myronf's Avatar
Woodek to hear that I am not going crazy! Let me know if you figure out what the problem is.
Myron
Old Jun 1, 2009 | 06:59 AM
Then this is what my dealer told me. For the time being, use your other key (driver #2) and see if the problem still exists. If it doesn't, then its the key.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
12vancover
Oct 16, 2015 12:04 PM
