2-3 Shift heistation at Wide Open Throttle.
Old May 20, 2009 | 10:44 PM
Juiced46's Avatar
Hey guys. Im assuming this is not normal but who knows. When Im wide open when the trans shifts from 2 to 3 it seems to have a slight hesitation when shifting, it isnt a smooth transition from 2-3 as it is from 1-2. Has anyone else experienced this? I havent tried it shifting it manually with the paddle shifters. This is just with it in D going WOT
Old May 21, 2009 | 11:39 AM
Ballinger's Avatar
Slow down. You move too fast. You've got to make the moment last.
Old May 21, 2009 | 12:29 PM
470hpGS400's Avatar
OK, that one made my morning.
Seriously, I noticed the same. At times it just seems sloppy during shifts. And if you really want to get annoyed, floor it through 90 in manual mode and watch your speed and rpms drop before picking back up.
Old May 21, 2009 | 06:57 PM
pickncrew's Avatar
i've noticed the lag as well and have written it off as normal
Old May 22, 2009 | 12:22 PM
neuronbob's Avatar
This has been documented on video on this site in the past. There's a pause and drop in rpms at around 5k rpm in WOT. This is a "normal" thing for this car. Hell if I know what causes it, though.
Old May 22, 2009 | 12:44 PM
jfarabaugh's Avatar
here is a video of it....not mine
http://www.youtube.com/watch?v=7XoiuqOtuRE
and an idiot
http://www.youtube.com/watch?v=1dXtQZk4nEU
Old May 22, 2009 | 01:41 PM
neuronbob's Avatar
That second video was to demonstrate one of SH-AWD's more, um, practical uses. It wasn't necessarily idiotic at the time. I remember the thread it was in....
Old May 22, 2009 | 09:51 PM
Juiced46's Avatar
I just watched the video and that is not the same issue I am talking about. What Im experiencing happens immediately after the 2-3 shift when it engages into the next gear, I actually felt it on a 3-4 shift tonight using the paddle shifters as well. Its not that the RPMs drop slightly while in that gear like the video shows. There is a slight hesitation shifting to the next gear, its not a very smooth transition, but doesnt happen all the time, but most of the time.
Old May 23, 2009 | 08:33 AM
Chas2's Avatar
This is just a wild assed guess.
When was the last time you changed tranny fluid? Every auto Acura I have owned has a less than robust auto transmission, and I have found changing the fluid really helps.
In fact, I am dealing with a rough 1-2 shift in my 2G Legend now, which I also had in my 1G Legend
Old May 23, 2009 | 10:40 AM
psheu's Avatar
LOL.... what's next? take the RL off roading can you imagine our beautiful RL doing the "Ford, we build our truck tough" commercial with mud flying all over the place
Old May 24, 2009 | 08:57 AM
Juiced46's Avatar
Car has 75k on it and Im not sure if the fluid has ever been changed. I just picked the car up a few weeks ago. I will change it out and give it a shot.
Old May 24, 2009 | 11:23 AM
rtr's Avatar
rtr
RL owner
yea change your fluids and my white one is starting to shift a bit jerky compared to my black one.
Old May 25, 2009 | 12:35 AM
woodek's Avatar
After owning my 98 CL (with the rice paper transmission), I $hit every time my RL even has the SLIGHTEST hickup or weird shift change.
A little off topic, but I gotta ask........
Is it OK to shift from Auto to manual shift while moving in the RL? IE: driving 65 MPH down the road and shifting into manual, so you can manually downshift to a lower gear and slow down without braking? Im used to driving my RX7, and down-shifting manually, is QUITE normal (at least for that car).
My RL seems to do it fine, but I dont want to shift the tranny like that if its not made to shift from auto to manual while driving down the road at speed. Unfortunately, I LOVE Downshifting! I dont plan on doing it often in the RL, but dont want to mess somthing up if its not made to shift like that.
Thanks!
Old May 26, 2009 | 10:05 PM
neuronbob's Avatar
Yes, you can, it's a feature of the car to be able to do that.
OIC. I concur with the recommendation to change the tranny fluid and then see what happens.
LOL! "The Acura RL....indestructible on road, or off."
Old May 28, 2009 | 12:32 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
perhaps it is part of the ULEV management? It may be a point when at full throttle, the emissions exceed parameters and the engine management does it nanny thing?
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
iesu3423
Sep 29, 2015 08:04 AM
Brandle34
Sep 23, 2015 07:20 PM
