06 RL - "M" shifter light up?
Hello -
This evening I noticed that in the shifter area the "M" (next to D) isn't illuminated. Can anyone check to see if that M lights up in their car? It's probably just a burned out bulb.
Thanks!
Thanks!
If anyone has any tip on how to open the shift gate plate let me know. Thanks
It's actually one of the EASIER pieces to take out. You just open the cup holder and grab the bottom edge of that whole plate and PULL UP. It's held on by 4 clips (one in each corner). That piece around the shifter comes up as one piece with the heated seat switches.
Hope that helps some...
Were you referring to the piece including the heated seat switches or the silver shift plate? I've pulled the piece including the heated seat switches and that's fairly easily. I'm just not sure how the silver shift plate will come off.
This may or may not work...but when I face this issue in the future, I was thinking of trying LEDs. I came across these....
http://www.superbrightleds.com/cgi-b...nstrument.html
If you decide to go that way, please let us know how it works. Then you won't ever have to worry about bulbs again...in theory anyway
Hope that makes sense...
I'm referring to the piece that includes the heated seat switches only. The silver shift plate stays in place. Once you have the piece off, the bulb is accessible on the left side of the unit in the middle (below the silver shift plate). There is only ONE bulb there. It lights up the entire range of gear position indicators.
So are you saying all the other positions light up and just the M doesn't??? If so, then your bulb must just be out of place because there is only ONE bulb in there.
EXACTLY! You don't have to remove the silver shift gate to get to the bulb that lights up the shift positions.
BTW, where are you located in Seattle? I'm from Seattle and I recently took my car up there in September. We totally could've met up.
BoricuaTL
Apr 8, 2016 01:08 PM
Sep 17, 2015 09:01 PM
