Rear Windows Not Functioning
Old Feb 26, 2026 | 04:32 PM
Budheiser's Avatar
3rd Gear
We just bought a 2016 RDX and did not check the rear windows. Neither go up or down. I tried the pinch reset (holding each button up for 5 sec and then down and vice versa) with no luck. Checked fuses and all good. Could not find a relay to check.
It does have a fresh battery and I read where that sometimes causes an issue.
I changed the master switch, same result.
Next Step? I could pull a door panel off and check for power to the motor or maybe there is another idea?
Thank you
Old Feb 26, 2026 | 05:12 PM
is the window lock button engaged?
Old Feb 26, 2026 | 05:28 PM
Budheiser's Avatar
3rd Gear
The one on the master switch? No it is not
Old Feb 26, 2026 | 07:59 PM
altair47's Avatar
I have a constant problem with my 2013 RDX due to not using the rear windows; I have to press hard several times to get the window to come off the guides.
Old Mar 7, 2026 | 09:09 AM
samiam_68's Avatar
Does the front passenger window work?
Old Mar 16, 2026 | 03:27 PM
Thmanx's Avatar
Thank you
Yep, the repair guide basically says go straight to the source and check if the motors are dead, or the wiring from the switch to the motor is bad.
Attacehd is how to remove the rear door panels & test the motor.
File Type: pdf
File Type: pdf
smorehouse42
2G RDX Problems & Fixes
Jun 12, 2024 08:18 AM
Quiet.TL
Dec 8, 2022 01:10 PM
fuzzysig
Mar 25, 2017 08:47 PM
guitarjunky64
Sep 28, 2010 06:37 PM
myronf
Apr 16, 2009 07:19 PM
